Need help or wiring diagram for 98 Civic stereo
Old 11-15-2010, 01:50 AM
Nooch's Avatar
Default Need help or wiring diagram for 98 Civic stereo
I need a wiring diagram for the stock radio in a 1998 honda civic hatchback dx. I recently bought a new headunit and I need to depin/repin the new connectors. Unless someone else knows an easier way to do this.
This is my first time changing a headunit on any vehicle amazingly. hah.
Both connectors are NOT the same either.
Old 11-15-2010, 02:01 AM
First.EG's Avatar
Default Re: I need a wiring diagram or help for an EK.
cut the original plug of the car and splice in the new one
Old 11-15-2010, 02:20 AM
O.G. triple O.G.
NVturbo's Avatar
....so you bought an aftermarket headunit or a stock one? If it's an aftermarket, get one of those radio harness (Metra) from your local Walmart. If you're trying to install a factory Honda/Acura radio, Metra has car harness wires as well....
DO NOT CUT THE FACTORY RADIO PLUG . You will regret it later.
Old 11-15-2010, 04:55 AM
Former User's Avatar
Default Re: Need help or wiring diagram for 98 Civic stereo
Old 11-15-2010, 11:09 AM
Nooch's Avatar
It's an aftermarket one. Specifically a Sony GT250MP, the connectors are different clips. So I was wondering do I depin the old one and repin it into the new plug or am I supposed to get an adapter for them to connect? I just realized that the two connectors are probably using different size metal clips to connect within the clip. Aw ****. I'll check out walmart haha.
Old 11-15-2010, 11:27 AM
H-T White Ops
NOFX's Avatar
I just get an adapter from my local car audio shop.
Old 11-15-2010, 12:11 PM
Nooch's Avatar
Ya, I guess I'll have to do that or hit up Fry's. Walmart didn't have the right one, only for BOSE headunits. Wish this wasn't so stupid, gotta make **** more plug & play.
Old 11-15-2010, 01:11 PM
The Grumpiest
grumblemarc's Avatar
You need one of these.
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
DO NOT cut or de-pin anything. I've been using these for 15+ years.
Old 08-14-2011, 09:15 PM
Lespaul's Avatar
Cool and thanks for the quick rreply.Lespaul
Old 08-14-2011, 09:27 PM
Lespaul's Avatar
OK here goes... 98 Civic, removed radio, took radio apart, desoldered "incremental mechanical rotary encoder"...pot was so much easier to refer to a volume control back in the day!
Five pins. Two pins (momentary on/off) one side, Three pins opposite side + two anchor pins middle. ALPS & JAPAN only words stamped backside of switch. Circuit board has VR401 where that part goes to but no part #. Where/Who can I talk to to obtain this little bit of "hell" LesPaul
Old 08-14-2011, 09:37 PM
Lespaul's Avatar
Before the eyelids close...could someone post wiring schematic (the guts...inside) for AM/FM 98 Civic. Hope voltage/amp max loads are included for the volume control (i.m.r. encoder) Thanks...Les Paul
Old 08-15-2011, 02:38 AM
virgineg6's Avatar
Dont know if you noticed this but this thread is almost a year old, you should just start your own thread instead of bringing them back
Old 08-19-2011, 04:15 AM
charnrin's Avatar
Last year, I did cut and soldered to put Pioneer in. It's very hard work take an hour to done this job. Get the harness is the best way.
Old 08-19-2011, 04:17 AM
virgineg6's Avatar
Wow!!
slippery seal
Honda Civic (2016 - Current)
05-26-2017 09:25 PM
slippery seal
Audio / Security / Video
05-03-2017 08:23 PM
Danny_barca
02-15-2015 06:31 PM
onyxsnowfoot
03-12-2013 11:02 AM
sanders711
10-07-2002 09:31 PM
Quick Reply: Need help or wiring diagram for 98 Civic stereo
