z6 swap in ef
Old 11-13-2010, 11:06 PM
AlfieRoach's Avatar
Default z6 swap in ef
im gonna start on this project soon. Got a a6 block already, but since the wire harness is kinda haggard, i wanted to use a z6 wire harness is it possible to just use the z6 harness instead of chopping the a6 harness more? Like what would i need to be able to use the z6 harness like not converting from obd 0 to 1 but just using the z6 for engine and a6 for inside?
Old 11-14-2010, 12:02 AM
dohc4life's Avatar
Default Re: z6 swap in ef
Well obviously there's a big difference you'd have to hange your plugs on the engine harness to obd0 which would be a hassle or the opposite to obd1 and your vtec wires woudlnt go to the ecu if you do it that way do it right keep the a6 harness and run the 3 wires for vtec to the ecu
Yomage_EG
09-24-2013 11:26 AM
gothdroid
03-29-2011 09:59 AM
memorybox
09-26-2006 01:55 PM
Discosteak
09-19-2004 03:02 PM
genop
01-29-2004 07:48 AM
Quick Reply: z6 swap in ef
