Old 11-13-2010, 03:59 PM   #1
KnuckleZ
KnuckleZ's Avatar
Default Car bogs down while accelerating then dies as I slow down....
So this morning I was on my way home from work on my 93 EG Hatch (B series swapped)and I stepped on the gas coming out of the exit into the interstate and the car just bogged down. Tranny was fine because I could downshift and I could feel the clutch engage so I don't think it's the clutch. However, I would accelerate and the RPM's where pegged at 0 and as soon as I slowed down to pull over on the side of the road,the car died. Tried to start it right back up and the motor turned but that was about it. Waited a few minutes and gave it another try and it strugled to start like it had run out of gas but I had half a tank of gas. Waited another few minutes and it started right back up. It drove fine until I accelerated again and it did the same thing. Thinking it could be fuel related like pump or clogged filters. Any thoughts/similar experience?
I've been reading A LOT of posts but I'm simply trying to narrow it down.
Any thoughts appreciated.
Thanks
KnuckleZ is offline   Reply With Quote
Old 11-13-2010, 04:07 PM   #2
b20hatchek
b20hatchek's Avatar
dualcamhatch
Send a message via Yahoo to b20hatchek
Default Re: Car bogs down while accelerating then dies as I slow down....
fuel pump? could be lots of things but try and rule out the "could be fuel" issues
b20hatchek is offline   Reply With Quote
Old 11-20-2010, 03:05 PM   #3
KnuckleZ
KnuckleZ's Avatar
So today I replaced the fuel pump, fuel filter, plugs and wires and I still have the same problem.
I found out today that the car will shut off after a while of being idling. Then it takes about 10 mins for it to start back up. It looks to me that its temperature related? Still not throwing any codes. If I crank it for about 5 seconds, the CEL will come on but it won't stay on whenever the car starts again so I can't even get a code to reference from.
Could it be a sensor somewhere?
Old 11-21-2010, 05:45 AM   #4
KnuckleZ
KnuckleZ's Avatar
Anybody?
Old 12-17-2010, 05:11 PM   #5
coquieg6
1999 Acura Integra
My Garage
coquieg6's Avatar
titocoqui19@yahoo.com
have the same problem and no solution so im subscribing.
Current platform: 99 DC2
Barefoot Racing. based Nashville, TN
previous cars: 89 Astro 92 Cadillac 02 impala 86 Camry 98 Camry 95 EG 00 EM1 96 DB8
coquieg6 is offline   Reply With Quote
Old 12-17-2010, 05:16 PM   #6
civicsmoke
civicsmoke's Avatar
check your main relay. if thats okay, check your rotor inside your distrubutor for water.
Last edited by civicsmoke; 12-17-2010 at 05:17 PM. Reason: didnt notice this thread is a month old.
civicsmoke is offline   Reply With Quote
Old 01-08-2011, 03:28 PM   #7
KnuckleZ
KnuckleZ's Avatar
Ended up being the CPS. OBD1 so I had to replace the distributor.
thx
Old 01-09-2011, 04:36 AM   #8
ddongbap
ddongbap's Avatar
Sounds like a distributor issue. Or, a distant second, a ECU issue.
ddongbap is offline   Reply With Quote
Old 01-09-2011, 04:04 PM   #9
ktsciv93
ktsciv93's Avatar
map sensor...?
ktsciv93 is offline   Reply With Quote
2001, accelerate, accelerating, acura, bogs, car, civic, die, dies, gas, honda, integra, pressed, slow, slows, starts
