Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 11-12-2010, 05:54 PM   #1
serjey15
serjey15's Avatar
Default How To Set H22A1 Timing Belt?
Hey guys, so I tried searching couldnt find any help.
So pretty much Im trying to replace my timing belt on my H22a1, and I heard that these have an automatic tensioner, and that you need a special tool to losen it or something.
Does anyone know about this?
Also does anyone have a guide or picture on how to set it and is it possible to change thee TB without the "special tool"? thanks.
1995 Honda Prelude VTEC-Sold, Miss You
PS: I don't need your help Kronn 98SH
serjey15 is offline   Reply With Quote
Old 11-12-2010, 06:31 PM   #2
kmcormick9
Default Re: How To Set H22A1 Timing Belt?
I'll look it up on alldata. You can rent most "special tools" from autozone.
My GFs jetta manual said you needed a "special tool at the dealership" to change the headlight bulbs. That special tool- your bare hand.
kmcormick9 is offline   Reply With Quote
Old 11-12-2010, 06:37 PM   #3
kmcormick9
No special tool needed. I can email you a PDF of the whole job if you want.
Old 11-12-2010, 07:42 PM   #4
the171
1991 Honda Civic
the171's Avatar
you are supposed to use a special tool. The auto tensioner is a hydraulic unit and quite powerful. You are to remove it from the engine, then remove a service bolt out of the tensioner. You then insert a small screw driver into the service hole and turn to compress the tensioner. Sounds simple enough, but getting the service bolt back in the tensioner and then getting the unit back on the motor without having the tensioner rebounding on you is very challenging. It is also full of hydraulic oil so you have to try not to spill any while fiddling with the thing. The purpose of the special tool is to keep the tensioner in compressed mode while you work. I have done it a ghetto way, using a hose clamp.
Many will tell you the auto tensioner can fail causing engine damage. The H23A engine came with a manual adjuster kit that can be used on the H22 which is waaaay more simple and safe to use. I now use this and recommend it. You can but the kit with new honda parts for under $100.
the171 is offline   Reply With Quote
Old 11-12-2010, 09:27 PM   #5
serjey15
serjey15's Avatar
That woould be fantastic bro please do/
serjeycbr@hotmail.com
Old 11-13-2010, 02:59 PM   #6
minilogoguy18
^Just go on spoonertuner(dot)com and get the helms manual, thought everyone knew about it being hosted there.
93 BB2 - JDM H22a/T2W4 Euro R transmission
Originally Posted by PirateMcFred View Post
Everyone's ****'s broken and they can't find a Helm Manual to read.
minilogoguy18 is offline   Reply With Quote
Old 11-13-2010, 09:49 PM   #7
gstrudler
1997 Honda Prelude
gstrudler's Avatar
I'm sure it could be done without the tool, but it would be quite difficult. You have to keep the auto tensioner locked in place while setting the timing belt, and then you pull the tool out once everything is installed and you've verified everything is at TDC. It basically looks like a big 'C' bracket (but with straight sides) that goes around the tensioner. I believe Honda no longer sells these on their own; they only come with the kit, but I would check with your local dealership to be sure; they are only around $15 and well worth it if you can get it and want to re-use your tensioner. Of course, if you are replacing your t-belt, you should be replacing the tensioner as well. The auto tensioner was also updated, so if you are running a stock VT, the newer tensioners should work fine without any reliability issues.
1997 Prelude SH - 2.4L
(1997 del Sol VTEC - deceased) // (1987 CRX - deceased)
gstrudler is offline   Reply With Quote
Old 12-10-2010, 03:15 PM   #8
Steve and Nikki
can you email me it PLEASE miamylove2007@yahoo.com
Steve and Nikki is offline   Reply With Quote
Old 12-27-2010, 01:53 PM   #9
Steve and Nikki
Thanks every1 I went the way of a manual timing conversion kit. it was very easy !!!!!!!
Old 12-27-2010, 07:01 PM   #10
serjey15
serjey15's Avatar
Yeah I converted to manual tensioner too, no problems at all very reliable.
Old 12-28-2010, 05:39 AM   #11
mjolson
i have a prelude that has an auto tensioner from japan.(h22a) do i need to change it to manual tensioner.
mjolson is offline   Reply With Quote
Old 12-29-2010, 10:45 AM   #12
flyrod
flyrod's Avatar
Send a message via AIM to flyrod
special tool for autotensioner = zip tie
Stuff for sale: K20A longblock Hondata Stage 4B Chipped P28's
Lots of 4th Gen Prelude stuff: STR fuel rail NIB, Si Brakes, ABS
H22 cams, etc.
flyrod is offline   Reply With Quote
Old 06-23-2011, 12:28 PM   #13
preludelovr96
did anyone have any valve problems? I have an H22A1 and people keep saying I probably ****ed my valves
preludelovr96 is offline   Reply With Quote
Old 06-24-2011, 05:34 AM   #14
typemismatch
Honda owns me
typemismatch's Avatar
You'll only have valve problems if you didn't do it right, or if your belt broke.
1992 Prelude S - 469hp/340tq@15psi - 12.46@117mph
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread http://www.honda-tech.com/showthread.php?t=2944704
typemismatch is offline   Reply With Quote
Old 06-24-2011, 07:02 AM   #15
preludelovr96
Im pretty sure the belt broke, I was driving and the car made a wierd noise and then shut off, it makes a crazy whinding noise when I try to start it now
Old 07-06-2011, 01:09 AM   #16
1994preludevtec
1994 Honda Prelude
can someone send me the info on how to do timing belt plz..
lilpimp_2004_90@hotmail.com
1994preludevtec is offline   Reply With Quote
Old 10-22-2011, 01:00 AM   #17
1994preludevtec
1994 Honda Prelude
can u send me thefull pdf file on how o do timing on h22 thanks..
there are _ in between so _2004 and _90
Old 03-07-2012, 06:27 PM   #18
Danny Fallas
1994 Honda Prelude
Danny Fallas's Avatar
dann1990 dann_1990 dann_1990
Icon2 Re: How To Set H22A1 Timing Belt?
Hi there, I don't know if you still have the PDF but i need it because when I align the balancers i don't know how to.
The engine have a little vibration after this.
Thank you
Danny Fallas is offline   Reply With Quote
Old 03-07-2012, 06:43 PM   #19
hondasdohc
The two cams have the "up" mark on them put them up and make sure the other notches are directly parallel to each other and that they are aligned with the head/valve cover gasket area it should look like this cam1(-UP-) cam2(-UP-) make pretend the up is the top notch and the other two lines are the notches when the cams are aligned as in up will be straight up. The crank one is easy it has the arrow pointer on the block and on the crank gears. Now the balancer shaft is tricky but easy there is a bolt behind the block where the water pump is located but alittle under it take it off and insert a screwdriver in so that the rear balancer is lock when you spin it. The other one has a line on the gear and a line on the shaft put the line on the shaft with the arrow on the block. That should have your timing set.
hondasdohc is offline   Reply With Quote
Old 03-09-2012, 03:34 PM   #20
TheJGB3
TheJGB3's Avatar
Send a message via AIM to TheJGB3
Here it is for a H22A4
2000 Type SH*AEM Short Ram & brake pads*JDM Front strut bar*OEM lip kit*Clear sidemarkers*OEM carbon fiber trim kit*ASE Re-Certified Tech:A4 A5 A7 X1 P2 C1
2000 Civic EX*Si front grille*OEM fogs
TheJGB3 is offline   Reply With Quote
Old 03-09-2012, 03:41 PM   #21
Prudz_lude
Prudz_lude's Avatar
iTrader Rating: (1)
kaizenspeed put out an even better product than the h23 manual tensioner
http://www.kstuned.com/detail.src?SKU=Kai-H22TT&C=&S=
Wish they put it out a few months sooner :p
BB Squad #23 (v.2)
Prudz_lude is offline   Reply With Quote
99, bel, belt, change, engine, h22a1, honda, jumps, prelude, set, tensioner, timeing, timing, tool, vtec
