| Welcome to Honda-Tech! | ||
#1 |
Ok how can i fix this code i heard is one of the worst codes on the honda thing i know a lot of honda but this code its pissing me off my car is a 95 civic with the d16z6 engine rebuild but that code is pissing me off what could it be or what should i look for. no mods at all
#2 |
Moderator
2000 Honda CivicMy Garage |
If you don't have any performance problems, check the O2 sensor.
Don't guess, troubleshoot --------------------------------------------------------- Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV --------------------------------------------------------- Please don't PM me tech questions. Create a thread. |
#3 |
WELL I DONT KNOW THATS THE WAY I BOUGHT IT SO I DONT KNOW IF ITS THE SAME WAY MY CAR IS GOING TO RESPONSE OR IT NEEDS MORE POWER I DONT KNOW BUT ILL CHECK THE O2 SENSOR HOW CAN I CHECKED IT
#4 |
Moderator
No need for all caps.
Have you cleared the ECU to see whether the code returns?
#5 |
OK I JUST DISCONNECTED IT AND PLUG IT BACK IN I CHECK THE CODES AND NO CODES WHERE BLINKING MY CHECK ENGINE LIGHT WAS ON AND MY SRS START IT BLINKING AND NEVER STOP ( I PLUG THE PAPERCLIP TO THE LITTLE CONNECTOR BELOW THE GLOVE COMPARTMENT
#6 | |
Moderator
The SRS light blinks an SRS code with the service connector jumped when there is an airbag circuit problem. Now drive the car to see whether code 43 returns.
#7 |
yeah it blinks but never stops blinking the code 43 disappeer what could it be i heard it was a faulty ecu.
#8 |
Moderator
With the service connector jumped, are you saying the CEL is blinking a new code or that the SRS light is blinking?
#9 |
no the srs light is blinking all the time no pauses or anything could it be a faulty ecu
#10 |
Moderator
Only with the service connector jumped, right? If you unjump the connector, does the SRS light just remain on steady.
#11 |
no it turns off if i disconnected the srs and the check engine
#12 |
Moderator
If CEL code 43 does not return, then you are good to go.
For the SRS light, did someone remove an airbag?
#13 |
nope is intact and the code 43 dosent appear but still messing up
#14 |
The SRS blinks on them. Mine does at least. And it goes directly back off... And if you say the car is still messing up WTF do you mean???
#15 |
ok my srs light blinks and dont stop when i jumped the service connector to check my ecu. and my car still turns off by itself everytime i press the gas pedal and when is release it shuts off so i need to press the gas pedal all the time even to brake or it will turn off and i cant floor it once in a while cuz it wont rev so i need to press the gas little by little until i cross the 1200rpm range but that happens once in a while
#16 |
Moderator
How old are the plugs, wires, cap, and rotor? Have you checked the mechanical and ignition timings.
#17 |
i check that already the timing and nothing and mechanical what do you mean with that
#18 |
Moderator
Did you do this:
#19 |
Moderator
#20 |
ok when i do that connect the serivice connector does any light has to blink after connecting it
#21 |
#22 |
whats mod rage
| Tags |
| 43, 48, 95, accord, airbag, blinks, check, civic, code, codes, fitv, fuel, honda, leak, light, problem, srs |
