Go Back   Honda-Tech > Honda and Acura Technical Forums > Drag Racing
Old 11-08-2010, 02:17 PM   #1
TEAM ASSASSIN SI
Default WEIGHT REDUCTION
ok so im in the middle of weight reduction in my ek hatch i think i got to everything i could think of with out cutting the chassis lol. so i though lets talk about this subject what have you guys done as far as weight reduction.
10.50 @145mph COMING SOON 9SEC PASS
TEAM ASSASSIN SI is offline   Reply With Quote
Old 11-08-2010, 02:42 PM   #2
Garage 808 Hatch
2004 Chevrolet Silverado 2500HD
My Garage
Garage 808 Hatch's Avatar
http://www.facebook.com/graig.osborne WindowLiquor TM
Send a message via AIM to Garage 808 Hatch
Default Re: WEIGHT REDUCTION
sound deadening material, padding under carpet, sheet metal behind plastic panels, pin windows up and get rid of regulators, and door bars. heater motor and core, etc. if you're serious
Fat Jesus to those of you in the know
89 CRX HOTROD 8.85@167 on STOCK GEARS Garage 808 built
XBL : WindowLiquor TM
Garage 808 Hatch is offline   Reply With Quote
Old 11-08-2010, 02:43 PM   #3
JDM JEFFREY
JDM JEFFREY's Avatar
iTrader Rating: (1)
what class ?
how much does you car weigh?
how much weight do you need to remove?
wiring,door bars,brakes,everything that is no longer used and be taking out
heat,blower motor. this list go on...
West coast Fastest H2b A/M Street car 10.72@132.57 best 10.448@129
RLZ engineering ,QSD,SKUNK2,LASKEY RACING,KINSLER,SUPERTECH,Esa, KS tuned,Exospeed,MYERS COMPETITION MANIFOLDS,FCS FAB
JDM JEFFREY is offline   Reply With Quote
Old 11-08-2010, 04:31 PM   #4
kte324
kte324's Avatar
iTrader Rating: (2)
I have done about everything above except the windows. I plan on doing lexan and getting rid of them heavy windows and regulators.
93' Civic CX Turbo - B16-T 586whp @ 24psi C16
84mm-CP-Pauter-S2 Valvetrain/Cams-S362
kte324 is offline   Reply With Quote
Old 11-08-2010, 04:32 PM   #5
JDM JEFFREY
iTrader Rating: (1)
just make sure the class your running in lets you run lexan windows
Old 11-08-2010, 04:59 PM   #6
Mikeyto
lexan windows is only allowed in hot rod and above
Mikeyto is offline   Reply With Quote
Old 11-08-2010, 05:35 PM   #7
kte324
kte324's Avatar
iTrader Rating: (2)
Yeah, its pretty much a "hot rod" now. It doesn't have a dash and is missing a few class mandatory items.
Old 11-09-2010, 11:33 AM   #8
TEAM ASSASSIN SI
im running in sfwd so lexan not an option as it seats with 6 point cage 2550 lb.im trying to loose 100lb so far im up to 50lb by gutting doors and airbags is pretty much a track car now so i really don't need heather assembly but how much does weight is it worth removing?
Old 11-09-2010, 12:54 PM   #9
Poootie
Poootie's Avatar
Send a message via AIM to Poootie
how much do you( the driver) weigh.. Because i had an EK and it was 2356lbs with me in it... And i didn't cut anythingggggg.. And i still had heat and the back and passanger belts, rear bumper support and power doors.
Granted you have a 6 point. But damn , why is it 2500+lbs?
Team Xenocron/Xenocron Tuned/552whp@22psi/81mm/stock sleeved/10.64@137mph on 20psi.
Originally Posted by HybridMT View Post
"Do you know how long it takes to re-pack a parachute? Thanks for adding to the traffic congestion.."
Poootie is offline   Reply With Quote
Old 11-09-2010, 01:14 PM   #10
Poootie
Poootie's Avatar
Ok!! Lets see what you HAVE to keep to be legal for SFDW!!
*headliner
*passanger and driver seat
*rear plastics
*carpet
*all OEM glass
*door pannels
^^ That being said , everything else is fair game..
Front and rear bumper support, manual doors which should have came on that car from the factory,the rear seatbelts and buckels,if you get a fuel cell like the NRG Tech one you can save about 14lbs over the stock one, lighter wheels like skinnies,sound material,heater core is you can stand being in a soda can for a car in -32*, swapping to a steering wheel without a airbag.
At the extreme you cna cut the sheet metel thats behing the rear plastics. But seriously? Why? when you have a turbo car.
Better option is CF parts (hood, hatch, Fiberglass front )
Old 11-09-2010, 01:27 PM   #11
TEAM ASSASSIN SI
I WEIGHT 140 POUNDS WET LOL dawm your ek was light as hell
Old 11-09-2010, 01:28 PM   #12
reddcoupe
reddcoupe's Avatar
i chopped the hell out my ek coupe an its still heavy at this point so much is gone not sure what class i qualify for
boost addicts racing patiently waiting to take over the streets of nyc
reddcoupe is offline   Reply With Quote
Old 11-09-2010, 02:58 PM   #13
Poootie
Poootie's Avatar
i was 140lbs at the time also.. I'm 160lbs now ( i have to take two $hits b4 i drive the thing). I need to go on a jockey diet!
I still had a tonnn of stuff to take off , if needed! I was just too lazy to do it..
I seen your car at Fall Nat , sounded gooood. I think you need to focus a lil more on setting the suspension up better, and scaleing the car. What does you 60's look like?
I don't see you needing to cut the car whatt soo everrrr!
Ps: I just seen your sig.. Thats a hugee MPH for that ET! I assume you are spinning.
Old 11-09-2010, 03:18 PM   #14
redboost10
redboost10's Avatar
you should be able to get a sfwd ek hatch to 2250...i got mine down to 2236. thats with glass still of course.
98 rwd civic 7.40 @ 179
www.stohr.com custom carbon fiber parts
redboost10 is offline   Reply With Quote
Old 11-09-2010, 03:43 PM   #15
Poootie
Poootie's Avatar
Old 11-09-2010, 04:27 PM   #16
2point2
2point2's Avatar
crx
Turbocharged CRX w/Stock H22
10.73 @ 137mph
Pics and Info
2point2 is offline   Reply With Quote
Old 11-09-2010, 05:20 PM   #17
2literCR-X
2literCR-X's Avatar
Send a message via AIM to 2literCR-X
Originally Posted by 2point2 View Post
crx
LoL
K-series all the way!
'95 Civic EX: K-series STOCK MOTOR with pt67 9.90 @ 136 missing 5th gear.
*TREBLIC TUNED*
2literCR-X is offline   Reply With Quote
Old 11-09-2010, 08:36 PM   #18
unusual71
unusual71's Avatar
trunk support webbing, hood support webbing
extra wiring adds up fast
rubber/insulation mat that is strapped to the firewall
and the rest of the sound deadening tar, too.
The heater core
abs, a/c, p/s,
and extra brackets
unusual71 is offline   Reply With Quote
Old 11-10-2010, 06:23 AM   #19
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
crx
What does yours weigh?
88ED8 is offline   Reply With Quote
Old 11-10-2010, 01:00 PM   #20
Ls_dx
Ls_dx's Avatar
iTrader Rating: (5)
Send a message via AIM to Ls_dx
I wish I still had a heater
JRL TUNING
FULL RACE
T1
Ls_dx is offline   Reply With Quote
Old 11-10-2010, 01:09 PM   #21
HamiltonRex
HamiltonRex's Avatar
I gave up on weight reduction when I decided to drag race with a DSM.
Pulling apart your wiring harness and removing everything out of there that you deleted. Thats a ton of wiring.
All sound deatening, use dry ice to get the stuff off the floor, it works very well, and removes it clean.
Just basically removing any misc things you don't need, seatbelts, etc, heatercore, all your ducting under the dash.
Then start using some lightweight parts, like cf doors/hatch/hood/fenders, remove your bumper beams, etc.
Lighter brakes, lighter wheels, it can get expensive though to shed that last bit of weight.
1g awd auto dsm
9.9 @ 139
HamiltonRex is offline   Reply With Quote
Old 11-10-2010, 03:12 PM   #22
TEAM ASSASSIN SI
spinning like crazy plus tranny giving me a hard time i've been catching 1'66 1'68 60' with the power the car made it should be in the 9's hopefully i can get there before the year ends.
Old 11-10-2010, 03:39 PM   #23
Poootie
Poootie's Avatar
what are you doing for boost controle?
Old 11-10-2010, 03:46 PM   #24
narfdanarf
narfdanarf's Avatar
Send a message via AIM to narfdanarf
My em1 is pretty bare...no heater core, no rear plastics, no sound deadening, no firewall mat, only a driver's seat, gutted the innards of the dash, removed a hell of a lot of wiring and extra bolts and stuff and it still weighed 25xx without me...I'm going to replace the driver's seat with a kirkey, I have rear skinnies to put on, gonna pull the sunroof out and put an aluminum plug in it. Don't really know what else to do besides door bars.
Round 2 build
narfdanarf is offline   Reply With Quote
Old 11-10-2010, 03:55 PM   #25
boosted2.4
boosted2.4's Avatar
^^^ How is your car still that heavy? My em1 with basically the same weight reduction (still power windows, still has sunroof, all the wiring, and all seats but driver is a kirkey) and it weights 2320 with a full tank of gas and my street tires without me in it.
boosted2.4 is offline   Reply With Quote
92, bumper, civic, core, coupe, crx, doors, ek, em1, extra, heater, honda, power, rear, reduction, removing, support, weight
