91 Honda Accord No fuel at rail.
Old 11-10-2010, 01:05 PM
Rickum's Avatar
Icon6 91 Honda Accord No fuel at rail.
I have a 91 honda accord that was running (but weak) and replaced the f22a motor in it.
Trying to start it I found that the fuel pump is not running so as i did a few years ago i replaced the pump relay from under the dash and the pump still wont run. is there anything else other than droping my tank and replacing the pump i can check?
Old 11-10-2010, 09:47 PM
Chiovnidca's Avatar
Default Re: 91 Honda Accord No fuel at rail.
Fuses? Are you getting power and ground at the pump?
Old 11-11-2010, 01:18 AM
Technical Hero
HondaPartsHero's Avatar
I would also check all your engine and frame grounds.
Old 11-11-2010, 02:04 PM
Rickum's Avatar
I checked all fuses and all are good! will check for power at the pump soon as i get the use of the lift again, I have ground effects all around now and cant even drive it up on my ramps. Thanks and will post what i find out.
Old 11-11-2010, 07:02 PM
Chiovnidca's Avatar
The fuel pump connector can be accessed from inside the trunk i think.
Old 11-12-2010, 08:16 AM
dohiot's Avatar
is the ground to the intake hooked up cause mine was doing the same thing and the ground to the intake was not hooked up but as soon as it was hooked up it kicked on right away
Old 11-12-2010, 12:19 PM
Rickum's Avatar
where is the ground to the intake located? and will that keep my #2 fuse from getting power? #2 is a good 30 amp fuse but it has no power to it with key on or off.
Old 11-13-2010, 12:24 PM
Rickum's Avatar
Icon7 Re: 91 Honda Accord No fuel at rail.
Ok Just to sum this all up! If a ground is a ground that is not attatched any where that is supposed to be it can be a nightmare. I found my ground under the distriitor that connects under a large wire support. hooked it up and started right up. I want to thank everyone that helped and thank you for Honda-Tech for being here online. will keep this posted to help others with this problem.
Bail2good
03-27-2020 11:14 AM
tribalpnoy
12-11-2009 08:04 PM
mtnman
08-22-2004 08:10 AM
Quick Reply: 91 Honda Accord No fuel at rail.
