Civic 99-00 DX hatchback - How remove license plate light covers to change the bulbs?
Old 11-01-2010, 05:38 PM
Team_Insane's Avatar
Default Civic 99-00 DX hatchback - How remove license plate light covers to change the bulbs?
So I own a 2000 Honda civic DX Hatchback and I'm wanting to clean the reat license plate light covers and swap out the bulbs, but I can't get them to come off. Any help on how to remove it would be nice thanks!
Old 11-01-2010, 11:25 PM
Default Re: Need help! Civic 99-00 DX hatchback
39 views and nothing? bump!
Old 11-02-2010, 12:20 AM
H-T White Ops
NOFX's Avatar
I remembered removing the license plate lights on a '97 CX hatch, but those were just held in by two Phillips screws, so I figured you couldn't have overlooked that.
But I knew that in 1998 Honda added a lift handle to the rear, right above the license plate. So that could very well have changed the design of the license plate lights.
So I checked on HondaPartsDeals.com for a pic and what do you know, there it is.
Here's the little image I made from their pic to better explain.
Looks like the '96-'97 hatches have license plate lights held in with two Phillips screws, but the '98-'00 hatches have some sort of clip in license plate light assembly.
I'm not sure how hard they'll be to remove, but I'd imagine this means they can be pried out.
Old 11-02-2010, 06:36 AM
damien1023's Avatar
I'm pretty sure when I did this to clean the lens on mine I just used a flat head screw driver and pried the side off. I believe it was held in by clips so just be careful and take your time.
Old 11-02-2010, 10:54 AM
D50boy's Avatar
Default Re: Civic 99-00 DX hatchback - How remove license plate light covers to change the bu
There should be a tab that you will have to move to unhook it in order to pull it out. It breaks easily so be careful. I found that out the hard way. I need a new one.
Old 11-04-2010, 07:04 PM
Thanks guys!
Luke G.
Lighting
01-04-2009 01:01 PM
tigueremalo
02-11-2007 11:30 AM
zakiu
08-11-2001 09:19 AM
Quick Reply: Civic 99-00 DX hatchback - How remove license plate light covers to change the bulbs?
