2002 honda cr-v no ac
my 2002 honda cr-v the ac stop working
no compressor, blower, condenser fan, compressor and clucth OK fuses and relay OK. I have a book from Alldata with good instruction but I can't find the problem.
Thank you,
rayrod
Thank you,
rayrod
Re: 2002 honda cr-v no ac
May be your blower power transistor. See these threads:
http://www.crvownersclub.com/forums/...ad.php?t=11704
https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/cabin-fan-not-blowing-2855314/
You need to do some diagnoses but they have been having issues with the compressor seizing up and the whole system may need to be replaced if its contaminated .
Thank you Redbull-1 for you great information about my car problem
I believe was a coincidence my next test was the Power Transistor I have the book from Alldata but even with the book some times you need more help. One of your links show you how to test it this is the way I test it, we also have a 2007 honda Element that have must of the relay and the Power Transistor are the same I remove the one from the 2002 test it on the 2007 No good then I use the 2007 and place it on the 2002 and the ac work find. Only on problem was the Condenser fan not working I test it out and was bad I replace the fan Motor is about $68.00 in Advanced auto parts and works perfect. Then I remove the Power Transistor and install it back in the 2007 honda. I follow the instruction on one of your links on how to fix the Power Transistor Radio Shock 99cents resistor did it, and the ac is working perfect.
It is good to see that people like you and others in this forum care about others. Thank you for all you help and also JDC5 and AK94GSR that show the interest on helping. I believe my original post was move I don't know the reason but is here anyway.
Any question I will be here to help.
rayrod.
rayrod.
silk509
07-15-2010 05:29 AM
