custom wire harness?
Old 11-06-2010, 09:10 AM
  #51
vtekthis's Avatar
Default Re: custom wire harness?
Originally Posted by 92redhatch
The day I go motec or aem series 2 I'll still use the factory harness. The only reason I see people buying a 1000 dollar harness is for the wire tuck.
did u just use motec and aem in the same sentence?
Old 11-06-2010, 09:12 AM
  #52
tony1's Avatar
Lol
Old 11-06-2010, 09:18 AM
  #53
92redhatch's Avatar
id rather do my own wiring and spend my money somewhere else. a nice harness isnt on the top of the list as long as everything is working fine.
Old 11-06-2010, 12:35 PM
  #54
tepid1's Avatar
Originally Posted by 2k.civic.si
$1000 bucks for a harness! *looks over at weller and hakko stations setup on the workbench*
A good harness starts around $3k
Old 11-06-2010, 02:00 PM
  #55
DSRxCandyh2bEG's Avatar
I made my own, but Ryan from rywire is my house mate.
In all honesty, Rywire is the way to go...
Old 11-07-2010, 03:08 PM
  #56
SonicRacing1's Avatar
RICHIEWERKS MOTORSPORT ELECTRONICS 5150
if ur on the westcoast... based outa socal city of commerce this is the spot u wanna go 2
4 any an all ur wiring issues from a basic wire tuck to a full millspec harness for any car not just HONDAS in specializing K-series heres a few pics of hes work he has done sum of the westcoast fastest cars from JERRY BUILT ALL MOTOR CAR to HONDATA JAVIER LOARCA SPFWD very good customer service so call or stop on by every1 welcome u never know BBQs are a random event there lol..
Old 11-07-2010, 08:44 PM
  #57
boostedb20z's Avatar
Im in the middle of my harness for my swfd and i have done away with everything under hood fuse box and all under dash wiring now my ? is what is the difference in the logic gounds for the ecu and the power grounds?? and was also wondering where should the load detector for the alt go. does it go to the alt and just send the info back to the ecu? thanks guys any info would be great
Old 11-09-2010, 12:26 PM
  #58
h22 civic's Avatar
their is nothing more i would rather do then call someone and just order a harness but some peoples thought on the word custom are not the same as as others to say the least...my car is a obd2a civic with obd1 95 prelude motor in it im running a aem sereis 2 ecu running coil on plug vtec killer cams so dont need any of the vtec ****,,wide band so dont need any factory o2 ****,,non of the egr stuff,,no iacv,,no iab,,,no evap,,,etc map sensor is different form factory and remote location ,,etc,etc so basically i have a total of about 40 wires in my whole harness...seems like most of the people that ive talked to just want to take your harness and put some shrink wrap on it ..i would feel better if i did it my self ,,
Old 11-09-2010, 12:48 PM
  #59
Garage 808 Hatch's Avatar
^^ thats why I was saying they'd need my car there to build the harness. Custom to me means built for my specific application, in my car.
Old 11-09-2010, 01:15 PM
  #60
Turbo-charged's Avatar
funny one would only do a harness for the wire tuck "look". hell after digging deeper and finding out how much goes into what you DONT see under the covering is the crazy part. id be willing to bet most of these harnesses available, even though they "look" good, are still far from correct on the inside.
Old 11-09-2010, 01:29 PM
  #61
tony1's Avatar
We do custom harnesses all the time without having the car here, our harnesses are built to drawings, which are drawn around your car/specs.
A harness should never be built 'in the car' to where it's not removable, so the car is not needed to build it, only some details for the drawing.
Old 11-09-2010, 01:42 PM
  #62
Do you accept Crayon drawings? its all i can do
Old 11-09-2010, 01:44 PM
  #63
tony1's Avatar
Yup, even on a napkin.
Old 11-09-2010, 01:50 PM
  #64
sick!
Old 11-09-2010, 05:23 PM
  #65
locash's Avatar
If you saw some of the **** that Tony has drawn, you'd think that they just let anyone use high end graphics software like Microsoft Paint. With that said, he prefers bright colors and only freehand work. Don't bother using high tech methods of drawing straight lines either.
Old 11-09-2010, 06:04 PM
  #66
kantspell's Avatar
Originally Posted by redboost10
kataku2k3 (ht name) made mine. here is a picture of it. i just listed this for sale yesterday as well.
i must say this is sick i love it. some day i will have one like that
Old 11-09-2010, 06:13 PM
  #67
Zer0_SpeedWorks's Avatar
emailed rywire for my harness,does your pro10/ps92 and nlr a1000 integrated to your main harness?
Old 11-09-2010, 08:37 PM
  #68
Originally Posted by tepid1
I'll ***** a couple pics of my T1 harness.
Some key features.... Autosport connector at the firewall, setup for my Motec SDL dash, setup for my E888 expansion box, setup for a M&W Pro Drag 4, 8 injectors, T1 trigger, strain, gear position, G-force accelerometer, tons of additional sensors.... etc
The ignition harness was done by T1 as well and on it's own Autosport connector. I didn't want EMI to become an issue so that is why I seperated the system like that. On my last build it was an issue.
Do it right the first time or don't do it at all. I lost a motor due to a shitty wire job, well there were other reasons too....
where is everyone getting these nice relays all i can find are your plan one any info would be nice thanks
Old 11-10-2010, 01:37 AM
  #69
tepid1's Avatar
Waytek wire has them
Old 11-10-2010, 05:20 AM
  #70
does that harness use break outs or just heat shrink where it splits?
Old 11-10-2010, 05:41 AM
  #71
tepid1's Avatar
That would be a question for Tony, if you're asking me, Joe. I don't think Raychem/Tyco makes a 20+ breakout. It does look like it's sealed up with glue though.... looks like the same glue used for sealing up the rest of the heatshrink.
Old 11-10-2010, 06:18 AM
  #72
hello1320's Avatar
Is it possible to put obd1 clips on the motec harness u make ...for the aem guys
Old 11-10-2010, 07:04 AM
  #73
tony1's Avatar
You could put obd1 connectors on one of our harnesses but you'd have a bunch of wires left over with nowhere to go. We run a lot of sensors on our Motec setups.
Old 11-10-2010, 07:05 AM
  #74
tony1's Avatar
Seriously, if you're going to spend the money on a good harness, put a good computer on the end of it.
Old 11-10-2010, 07:12 AM
  #75
are you saying aem is not good? lol
Quick Reply: custom wire harness?
