How do you drain coolant on the V6 from the block plug?
Old 10-07-2010, 08:11 AM
atikovi's Avatar
Default How do you drain coolant on the V6 from the block plug?
I'm flushing and changing the coolant and want to get all the old stuff out and the radiator only drains half the total amount. I can't see any easy way to reach the plug with the converter right next to it.
Old 10-07-2010, 12:09 PM
skracer13's Avatar
Default Re: How do you drain coolant on the V6 from the block plug?
Block Plug (I'm guessing your referring to the freeze plugs) are there to relieve pressure in case of freezing, (if not then you shouldn't be removing your threaded plugs anyways) not to flush your coolant system. Do this: remove both hoses from the radiator, remove the thermostat, and force water through your engine with a water hose. Way more efficient.
Old 10-07-2010, 12:41 PM
redbull-1's Avatar
Install a hose (A) on the drain bolt (B) located at the rear of the cylinder block, then loosen the drain bolt.
When the coolant stops draining, tighten the drain bolt. Remove the hose.
Old 10-07-2010, 01:16 PM
BLKFLSH's Avatar
+ 1 Don't forget about the hose. I didn't put a hose on it, and got sprayed with antifreeze. I would not flush it, because some of the water will stay in the engine, and dilute the 50/50 coolant you put in. Just drain the radiator and the block, and refill. Takes just under two gallons.
Old 10-07-2010, 05:02 PM
atikovi's Avatar
Yes I have the manual and see that picture but there is no freakin way to get a wrench on the bolt let alone turn it, what with the converter and axle right behind it.
Old 10-07-2010, 05:04 PM
atikovi's Avatar
Well the hose wouldn't be a problem now since I flushed it 12 times through the radiator drain and there is nothing but pure H2O in the engine. How the heck did you even get a wrench on it?
Old 10-07-2010, 05:49 PM
BLKFLSH's Avatar
Have you tried a socket, and small ratchet. It's been a few years since I did it, but I don't remember it being that hard. You definitely have to get under the car, so make sure it's SAFE.
Tap water is not good to mix with long life coolant. I know the manual says not to use regular water. All that pure water left in the engine will dilute the 50/50 mix antifreeze too. I would get as much of that water out as possible.
Jeff Lebowski
11-14-2016 05:02 PM
xXViperXx
05-06-2010 06:39 AM
Rvu
01-29-2010 08:15 AM
TypeRuz
12-05-2003 09:15 PM
speedymon
11-14-2002 10:44 AM
Quick Reply: How do you drain coolant on the V6 from the block plug?
