engine bay
Old 09-28-2010, 05:19 PM
hello1320's Avatar
Default engine bay
Shaving my bay.......I was told that if filler it used it WILL crack. It's seems impossible to get the welded holes to look right without using filler. has anybody done this with filler and had it not crack. It seems that with solid mounts and all the forces on the chassis it would crack. The mounts were pulling off the spot welds so there has to be some extreme flexing going on. I don't know....never got a straight answer from anybody that has ACTUALLY done this. After I make a decision about this ill finally post pics of the car . Thanks
Old 09-28-2010, 05:30 PM
Luserkid's Avatar
Default Re: engine bay
Ive done mine with a fiberglass mixed filler over my welds, havent had a crack minus the one when my motor hit a spot. I have Hasport shelf mounts and full race traction bar with front engine mount.
Old 09-28-2010, 05:32 PM
j-bird20's Avatar
dont try to lay a bed...use spot welds all the way around. once ur finished grind it nice and smooth. then apply wuts called "putty glaze".you can lay it alot smoother than regular bondo and it sands away alot easier. as long as everything is welded correctly it wont flex and crack. u can use 100 gritt to cut the glaze fast then use a 180 to smooth it all out. if u want u can use alittle mist of black spray paint to see the inperfections. after all the holes are done i would hit the whole engine bay with a nice high build primer. scuff it down and spray it.
Old 09-28-2010, 05:38 PM
hello1320's Avatar
Thanks alot......I cannot afford to have it crack....I've acquired the exact paint that's used on the lambo revention....sorry if this is not drag related but a lot the other guys cars are street cars....Iam using evercoat rage extreme ...that what was recommend at the supply shop...if I even use it
Old 09-28-2010, 05:46 PM
j-bird20's Avatar
no problem. the lambo revention color is a flat/satin silver from wut i can see?
Old 09-28-2010, 05:54 PM
DC2_117's Avatar
I shaved the hell out of my bay. It's like glass. I haven't had any issues with mine yet. I am pretty sure we have similar setup's.
Old 09-28-2010, 06:20 PM
hello1320's Avatar
Did you use filler
Old 09-28-2010, 06:22 PM
hello1320's Avatar
If you only knew what it took to get the EXACT color
DC2_117's Avatar
Did you use filler
Yes, and mar-glass, some rage, and some metal glaze.
Old 09-28-2010, 07:05 PM
hello1320's Avatar
How long has it been done....do u race the car.......serious racing
Old 09-28-2010, 07:20 PM
01DC4's Avatar
lol.
sasinorm01
07-12-2009 06:38 AM
JDM Vision
07-20-2006 12:21 PM
92 CIVIC HATCH VX
11-11-2005 10:28 AM
b16hatche
11-07-2005 03:43 PM
vtecmike1
11-19-2003 07:19 AM
Quick Reply: engine bay
