Go Back   Honda-Tech > Honda and Acura Technical Forums > Wheel and Tire
Old 09-11-2010, 01:54 PM   #1
tnywy
Icon2 Is there issues if one tire has a lower speed rating then my other 3?
Hey all,
Please help me out if you could - I need to replace a tire on my 2007 Honda Accord EX, and my tires currently have v rated tires. But there's a nail in one of my tires and I'll need to replace it. Would it be disadvantageous to have one of my tires have a H-rated tire and different from the rest? I don't drive any more than 80 mph usually, and I only drive it to work and occasional short trips to restaurants/markets. Help please?
tnywy is offline   Reply With Quote
Old 09-11-2010, 02:39 PM   #2
nsxtasy
H-T Order of Merit
Default Re: Is there issues if one tire has a lower speed rating then my other 3?
Yes and no.
It shouldn't be a problem to use tires with different speed ratings because of their speed rating, as long as you're not exceeding the speed for the lowest speed rating you have - in this case, 130 mph for the H rating.
However, it's a bad idea to use tires that have significantly different performance characteristics from each other. For example, if you have three grand touring all-season tires, it's a bad idea to mix them with one (or more) maximum performance summer tires, because they will behave differently from each other, and this different behavior can change depending on the conditions. It can not only degrade your car's handling, but also make it unpredictable. That's why it's best to use four tires of the same make and model where possible, and otherwise to mix them only with tires in the same performance category.
nsxtasy is offline   Reply With Quote
Old 09-11-2010, 04:16 PM   #3
tnywy
Thanks nsxtasy. I thought that'd be the case. I'll pay the extra to get the same performance tire then
Old 09-12-2010, 05:16 PM   #4
CountDracura
CountDracura's Avatar
No tire or vehicle manufacturer will ever recommend mixing speed ratings. While you wont run in to many issues with top speed stability as nsxtasy has fore mentioned, the sidewall construction does change from speed rating to speed rating. If you are forced to mix speed ratings, it is recommended to place the higher speed rated tire on the rear so as not to induce over steer on turns in inclement weather.
CountDracura is offline   Reply With Quote
Old 09-15-2010, 08:11 AM   #5
Cooper The Tire Rack
H-T Platinum Sponsor
Both nsxtasy and CountDracura (nice name, btw) have good points. In a pinch, I am not against selling a pair of H-rated tires if the same tire isn't available in V-rate. But that's as low a step I am willing to take. Going from V to T or lower may cause remarkable differences in handling, lateral roll, oversteer, etc.
Cooper - Wheel and Tire Forum Moderator
1-800-428-8355 ext. 743
The Tire Rack Tech Center
Cooper The Tire Rack is offline   Reply With Quote
accord, crv, fit, happen, honda, lower, mix, mixing, rated, rating, ratings, replace, speed, tire, tires
