Replace front wheel hub or just bearing?
Old 09-10-2010, 11:38 AM
RacerTim's Avatar
Default Replace front wheel hub or just bearing?
I need to replace a front wheel bearing on my car. I'm sure I can do it on my own, or take it to a shop to press out, but I'm sure it will be a pain with lots of swearing involved either way. Would I save myself some time and sanity if I purchased a front hub assembly that included a new wheel bearing?
I found these on eBay for about the same price as a new bearing:
http://cgi.ebay.com/ebaymotors/ACURA...-/250646295805
Yes, I know a factory bearing is going to be better quality, but that isn't the question I am asking. Thanks for your help!
Old 09-10-2010, 12:06 PM
EHondaJDM's Avatar
Default Re: Replace front wheel hub or just bearing?
Take your spindle off and have a show press a new hub bearing in if u got the cash.
You could get a whole spindle from a junkyard and thrown it on if your strapped fr cash
Old 09-10-2010, 12:21 PM
BlueIntegraBoy's Avatar
I would let a shop press in the bearings. It's headache free. It wouldn't matter if you just purchased the combo as opposed to just the bearing. You would still need to press out and press in. Only reason I could see in replacing just the hub is if the knurl for studs were stripped in any way, or you have a broken stud(s). Reuse your hubs and just purchase OEM bearings. Would be a bitch if the aftermarket bearings wore prematurely and you would have to disassemble your knuckles again.
Old 09-10-2010, 04:29 PM
follie gatts's Avatar
what he said ^
i have a thread about DIY front wheel bearings on here if you want to see what it takes. even if you can press them yourself, the inner race of the old bearing is seized on the hub in a way that you need something like this to get it free:
go to the shop if you don't want to buy a few hundred dollars in tools, especially if you don't have a press or an impact wrench.
EDIT: here's my thread https://honda-tech.com/forums/acura-integra-6/front-wheel-bearings-job-hub-tool-%5Bpic%5D-2610118/
Old 09-10-2010, 04:31 PM
donut.'s Avatar
Do not buy that hub/bearing from that ebay link. It's showing a rear wheel bearing/hub but listed as a Front. There's no reason to replace your front hub, unless it's bent or something. Just get the bearing.
Old 09-10-2010, 05:44 PM
racebum's Avatar
vatozone actually carries good usa made timken bearings. just run down and grab one, press it in and go about the day
Creator
04-14-2011 06:03 AM
z6hatchboy
02-06-2009 06:31 PM
kyorishin
10
04-22-2008 07:40 PM
petergriffen
08-11-2006 08:44 PM
Bnjmn
09-20-2005 03:43 PM
Quick Reply: Replace front wheel hub or just bearing?
