Old 08-31-2010, 09:32 AM   #1
all-mtr-teg
all-mtr-teg's Avatar
Default Power steering cooler, is it necessary?
Is the power steering cooler necessary, the one that mounts in front of the a/c condensor onto the radiator support? I'm trying to tuck my a/c and p/s steering hoses and lines, and was thinking of bypassing the p/s cooler.
AnthraxVX, Alchemist, SiREK4, airbag, redgsrguy, bambam, mtber, dfoxengr, kteller8, Mad Money, kelviiv, .xcalibur. , 98Luder, BandOi, B19Coupe, numberone, ferio_boy, r'truckin, project_dc2 http://www.hondamarketplace.com/show....php?t=2739839
all-mtr-teg is offline   Reply With Quote
Old 08-31-2010, 12:02 PM   #2
Drive 4 fun
Default Re: Power steering cooler, is it necessary?
As I recall, LS does not have, GSR has a loop, and Type R has a loop with some cooling fins. I think that part of the problem is that at higher rpms, the pumping generates heat. You could drive the system less, different pulley size, or try without. Not necesssarily a good idea if you track or hold at higher rpm.
Drive 4 fun is offline   Reply With Quote
Old 08-31-2010, 12:20 PM   #3
ruffrhyder
ruffrhyder's Avatar
iTrader Rating: (1)
I don't really see how the GSR "cooler" would even be effective. Like you said, it's basically a U shaped pipe mounted in front of the a/c condenser. There aren't any fins or large surface area to help dissipate heat.
Vouches: Combustion Contraption, Im poor, goldhatch94, sol_1, M.O.T.U., hondaboy4life, FTW_EG6, BILLY_BAD_A$$, monKK, meathook, skunk2.com
ruffrhyder is offline   Reply With Quote
Old 08-31-2010, 01:24 PM   #4
Drive 4 fun
A loop of aluminum tubing with full air flow could dissapate just enough heat to keep things below cooking temp. I was told that on a track, that the PS pump bearing and seal, and hose crimp, metal to rubber, take a beating on the LS and that the cooler is enough to help that. I guess some engineer put it there for a reason, the number crunchers would have stopped otherwise.
Old 08-31-2010, 01:29 PM   #5
Spawne32
Spawne32's Avatar
iTrader Rating: (3)
Send a message via AIM to Spawne32
If you really must go without it, i would run a good full synthetic PS fluid with a high boiling point instead.
DDTECHCAMS.COM - CNCWERX - OSIDETIGER - SPEED TRAPP CONSULTING TURBOS - SKUNK2
Originally Posted by 95LTX
my car hasnt had 02 sensors in.. forever. it roams around in a open loop speed density tune. killing small children and raping helpless mothers at night.
Spawne32 is offline   Reply With Quote
Old 08-31-2010, 02:58 PM   #6
SleeperGSR
SleeperGSR's Avatar
I think it depends on how you drive the car. For the roads and daily driving, i don't think you need P/s cooling. however, if it was designed into the car it must be there for a reason. So i would keep it unless its broken or you are removing the p/s compleatly. I go to hpde's alot and have noticed that the p/s resivor gets extreamly hot after a 30 min session. If i ever were to boil the fluid i would add some cooling, but i haven't yet. I will be switching fluids to a more high temp. is there an easy way to flush/bleed the power steering system???
SleeperGSR is offline   Reply With Quote
Old 08-31-2010, 03:04 PM   #7
Drive 4 fun
Again, I have heard of problems with the PS hose cooking at the metal rubber interface, that could happen before boiling. I would use the cooler unless for casual DD. RPM's to the pump seem to cause the temperature, and of course nobody revs, right??
Old 08-31-2010, 03:18 PM   #8
4stagecandy
4stagecandy's Avatar
i removed mine when i changed all my power steering lines to an fittings and hoses no problems as of 10,000 miles
4stagecandy is offline   Reply With Quote
Old 08-31-2010, 05:07 PM   #9
all-mtr-teg
Where do you live? How hot do your summers get? Here in cali, 115 oF in summer isn't uncommon.
Old 08-31-2010, 05:20 PM   #10
4stagecandy
i live in cali in riverside
2000, 94, accord, civic, cool, cooler, cooling, coolling, honda, integra, line, loop, necessesary, power, problems, steering
