reverse transmission problems
Old 08-26-2010, 03:04 PM
urcarslow's Avatar
Default reverse transmission problems
1994 honda accord automatic transmission makes a loud noise when put in reverse only??need help please noise is loud only when put in reverse its loud sounds like a durt bike if u press the gas would in reverse it sounds even more of a durt bike only does it sometimes but its loud n got to fix it quick<
can it b the cable?idk some people say it might b stretchsome1 help me please....
Old 08-26-2010, 03:06 PM
urcarslow's Avatar
Default Re: reverse transmission problems
some1 help please
Old 08-26-2010, 04:04 PM
urcarslow's Avatar
need help any1?
Old 08-26-2010, 04:40 PM
urcarslow's Avatar
bumptttttttttttttttttttttt need f help
Old 08-26-2010, 05:29 PM
MM Gruppe B
MAD_MIKE's Avatar
It makes 'braap-braaaap-braaaaap' like sounds?
Old 08-26-2010, 07:23 PM
HonBeer's Avatar
Like Mike said. CALM DOWN!! Take a few xanax and go to sleep. Its not a life or death emergency.
Old 08-26-2010, 11:50 PM
urcarslow's Avatar
i just need to fix asap 4 work thats it<<,nothing big
Old 08-27-2010, 03:24 PM
poorman212's Avatar
Hope you slept well. From the description of your sound/issue, I'd check the heat sheilds on the exhaust pipes....does the sound only happen when the car is cold?
Old 08-27-2010, 03:31 PM
urcarslow's Avatar
Old 08-27-2010, 05:39 PM
joe_accord23's Avatar
check if u need to change the fluid. the heat might have lost its viscosity. also sadly, u might need a tranny rebuild.
Old 08-27-2010, 10:42 PM
bseriescrxsi's Avatar
you are aware autos do make more noise in reverse because of the gearing right?
Old 08-28-2010, 02:03 PM
02 accord's Avatar
Sounds to me like the reverse spur gear is not popping into position and grinding, which coincides with making more noise when he hits the gas. Does the car move in reverse when it's making the noise?
Old 08-28-2010, 07:50 PM
ricerollz's Avatar
i think i know what your talking about my friend has the same problem in a DA9 like it sounds like some scratching noise or something and like the car wont reverse?? he got quoted and they just said 60.00 at some transmission shop or somethinggg
importtuner1413
12
05-21-2007 09:10 AM
el arbi
15
05-18-2003 09:06 AM
Quick Reply: reverse transmission problems
