injector wiring
Old 09-16-2010, 11:37 PM
  #26
TJChad's Avatar
Default Re: injector wiring
So you think your injector arent pulsing or you KNOW? If you're not sure if they're pulsing or not just uplug the injector you want to test jumper a test light across the terminals and try to crank the car. If the light blinks as though the injector would be pulsing your problem is not your electrical circuit.
Old 09-17-2010, 01:26 PM
  #27
jonathan13's Avatar
Did that, no pulse. It has a constant 12v coming from the power ground but no negative signals are being sent from the ecu to tell the injectors to pulse. Could the dizzy cause this? I read that a bad sensor in the dizzy could cause the ecu not to pulse the injectors... BUT wouldnt the dizzy not send spark if there was a sensor messed up within it?
Old 09-17-2010, 05:39 PM
  #28
TJChad's Avatar
There are several sensors inside the dizzy. One of them is used tor the ECU to know when to pulse the injectors based on camshaft position. It sounds like you have a car that you could flip parts too. Try slapping on a know good dizzy
Old 09-18-2010, 11:08 AM
  #29
jonathan13's Avatar
That is literally the only thing it could be I think... unfortunately I cant find anyone local with a dizzy to borrow so we may just have to spenr the cash and throw one at it.
Old 09-19-2010, 12:56 PM
  #30
jonathan13's Avatar
It was the dizzy! Praise Jesus! It's alive!
Old 09-19-2010, 04:01 PM
  #31
TJChad's Avatar
Good stuff
Old 03-10-2011, 02:50 PM
  #32
djones3361's Avatar
Icon2 Re: injector wiring
just wondering if you ever found the problem. I have a 98 civic ex with spark, fuel, and no injector pulse. After spending over 1000 at the dealer and still no solution, im almost ready to junk the car. someone help me.I repleaced dizzy still no luck.
Luserkid
Engine Management and Tuning
05-21-2012 06:00 PM
RxglassJAw
06-16-2008 06:33 AM
BAZ
04-01-2003 09:48 AM
dustin
06-17-2002 02:09 PM
Quick Reply: injector wiring
