Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 08-24-2010, 09:02 PM   #1
chueymuas
chueymuas's Avatar
Default why is my back lower than the front?
so like the title says, why is my back lower than the front?..the car is dropped on eibach sportlines, which suppose to be an even drop of 1.8 inches.. the springs are with tokcio blues and i have some blox lcas on
my car
cousins car..his sits evenly..and has same springs
chueymuas is offline   Reply With Quote
Old 08-24-2010, 09:50 PM   #2
buymesomedunks
buymesomedunks's Avatar
Default Re: why is my back lower than the front?
did you just install them? if so you need to let them settle for a bit. orrr you may have installed them backwards.
buymesomedunks is offline   Reply With Quote
Old 08-25-2010, 11:07 AM   #3
TunerN00b
TunerN00b's Avatar
Springs don't settle.
Now, if the bushings weren't correctly clocked, then they can slowly shift over time, as the extra stress of being ran out of position stretches / tears them.
They both look equally level to me. The front fender opening is larger than the rear, and a level car will always have more gap up front.
TunerN00b is offline   Reply With Quote
Old 08-25-2010, 02:52 PM   #4
eg2jr
eg2jr's Avatar
iTrader Rating: (7)
your cousin car is on a down hill street so his front end looks lower and your car rear end is on the drive way so your rear looks lower... ?
Parting out 110,xxx k20a2 type a engine. PM ME OFFERS AND WHAT YOU NEED
eg2jr is offline   Reply With Quote
Old 08-25-2010, 03:09 PM   #5
DC5krazy
ur shocks might be going out
DC5krazy is offline   Reply With Quote
Old 08-25-2010, 09:18 PM   #6
23LX23
23LX23's Avatar
I have tokico blues with the tokico springs and i have the same problem... except my front seems to have stood the same size as the stock suspension... and my back fits right above the tire
23LX23 is offline   Reply With Quote
Old 08-27-2010, 05:25 AM   #7
Colin
Colin's Avatar
iTrader Rating: (1)
Send a message via AIM to Colin
The age/condition of your shocks has ZERO effect on ride height. You could put a blown shock in place, with all fluid inside removed and it'll sit exactly the same height as a brand new out of the box shock.
I don't see a significant difference in height on those two cars. Between different locations and different wheels you can't judge from those pics, imo. And from my experience most lowering springs will lower the rear a bit more anyway. With such a front heavy car (FF) you usually want to lower the rear a bit more in an attempt to gain some front/rear weight balance.
Track Project = DB2 #896
LeMons Project = Steel Reserve DA9
Colin is offline   Reply With Quote
Old 08-27-2010, 09:36 AM   #8
Cynical 1
1995 Honda Civic
My Garage
Cynical 1's Avatar
Cynical Motorsport
x2. shocks do nothing for ride height.
also the rear wheel well opening is slightly smaller than the front, giving the illusion. look at a new 3 series bmw for another example.
Cynical Motorsport
Cynical 1 is offline   Reply With Quote
back, blox, car, cars, end, evenly, front, higher, honda, lower, lowered, lowering, rear, sit, sits, sitting, springs, usual
