IA 89 civic si (pocket rocket) Map Tuned
I am testing waters on my 6 year project car.
This car has a ton of aftermarket/race parts added to it to make it what it is today.. Car was just recently tuned at Map by the famous Jordan Schreyer. Car has made 406whp and 333wtq on a dynojet...
http://turbod16.com/viewtopic.php?f=3&t=46709&hilit=some info on the car.. Car is insanely quick.. I dd it at 17psi which is 350whp.. at 400+whp on 780/e85 it was little lean so it was backup to 17psi.. If you like what you see lmk id like cash maybe a bike.. LMK..
The parts list.
D16z6
Built
Arias pistons
Eagle rods
Honda bearings
Arp head studs rod bolts
Honda y8 head gasket
Zex 59300 Cam
Valve springs
Retainers
Shimmed&Ported oil pump 1mm
Oil pick up modified cut open
Ported z6 head exhaust port
Ported to match log manifold/gasket
Intake manifold ported to match head&hondata IM gasket
62mm H22 S Throttle body
Ported IM for 62mm
Act 4 pad unsprung HD
Turbo
CHRA T04E 60 Trim BB Precision
P-Fab Log manifold
2.5in Cold Pipe
2in Hot Pipe
Spearco Intercooler 3in
T bolt clamps
HKS Super Sequential
Tial 38
Hallman Pro black
3in down pipe E cut out
Apexi WS2
OBD1 P28 Ag-Engineering
Jordans Crome Pro
780cc Precision Delphi
Aem rail/regulator
Walbro 255
GM 3 bar
E85
Innovative cross frame bar
EM1 si wheels with new tires 195/55
Aem wideband gauge black
boost gauge in multi colors
Carbon fiber ele. oil gauge
KN&N filter cone *new
GR2 shocks/adjustable springs
stop tech front rotors sloted/new pbr pads
rear disc swap/ebrake works.
horn was upgraded to a TSX horn's and works flawless..
I dont know if im forgetting anything but thats all i have now i have receipts form the tunes.
http://i36.tinypic.com/2z8sryr.jpg
http://i37.tinypic.com/1g50y1.jpg
http://i37.tinypic.com/30dhufb.jpg
http://i33.tinypic.com/n1up9z.jpg
http://i36.tinypic.com/2vxofw0.jpg
http://i36.tinypic.com/2465ljm.jpg
http://i37.tinypic.com/2zp8iv8.jpg
Thats all folks.. ill get somemore later.. 6500$ New Price 5500$ as is.. i can pull stuff to lower price tag.
just did a oil change 5/30 gtx new filter purlator car has magnetic oil plug and it was clean..no oil leaks has all oem honda oil seals cam seal and both crank seals. motor was inspected while back and it all looked great internally...
The parts list.
D16z6
Built
Arias pistons
Eagle rods
Honda bearings
Zex 59300 Cam
Valve springs
Retainers
Ported IM for 62mm
Turbo
P-Fab Log manifold
2.5in Cold Pipe
2in Hot Pipe
T bolt clamps
Tial 38
Hallman Pro black
Apexi WS2
Jordans Crome Pro
Aem rail/regulator
Walbro 255
GM 3 bar
E85
Re: 89 civic si (pocket rocket) Map Tuned
BUmp for this clean *** 89 wish i had the funds for this well all i really want from it are the door panels and front seats but too bad not parting
if your interested in trading for a bike, what would you think about a wicked fast 2008 ZX-14, chipped with aftermarket pipe. (My buddy has too many bikes.)
here it is with stock pipes.
let me know what you would want for the rolling chassis and i could buy the intercooler and some piping since it's already fitted and such. Keep the interior stuff like gauges and such. and give me a price, so basically everything but your mounts/engine/trans/turbo stuff/ and axles. I'm looking for a new project for the winter and want to do a k-swap and supercharge it.
