D16 Block W/ Y8 Head
Old 08-15-2010, 03:08 PM
byrne_06's Avatar
Default D16 Block W/ Y8 Head
Alright i just completed the y8 head mated to the D16 Block swap today. I know alot of people were wondering what timing belt to use and everything else.
Head gasket: i used the Y8 headgasket cause it bumped my compression up to like 10.8
Timing Belt: I went with the Y8 timing belt, it is a very tight fit. Im a bigger guy and it took two of use to pull the belt over the cam gear for the first time. I would recommend getting a new tensioner also.
Really thats about. Good Luck if you have any more questions let me know
Old 08-16-2010, 01:06 AM
dohc4life's Avatar
Default Re: D16 Block W/ Y8 Head
so instead of buying a belt that fits nice and not stressing everything you put one on thats tight as **** and you have no way to tighten the tensioner lol ill go with the b7 belt thanks
Old 08-16-2010, 01:12 AM
BlanketJackson's Avatar
good choice
Old 08-16-2010, 07:35 AM
byrne_06's Avatar
it still has slack in it, there is no stress at all, if the timing belt made a real bad noise like it was to tight i would switch to the b7 belt but it dont so its fine. it also could have been the fact that i didnt change my tensioner so i was hanging up a little. but i did it successfully so thats all that matters, but from what i read you can use the b7 or y8 belt
StupidSlowRSX
02-15-2008 03:00 AM
buddy4002
11-10-2006 12:54 PM
SOHC_MShue
15
06-03-2005 06:18 PM
lohatch
06-15-2004 07:44 AM
Quick Reply: D16 Block W/ Y8 Head
