Where can I get a pressed wood cover under trunk floor mat for an 00 Civic?
Old 08-18-2010, 09:34 PM
  #26
EG'SUS's Avatar
Default Re: Where can I get a pressed wood cover under trunk floor mat for an 00 Civic?
Just make something big enough to cover the spare tire part..(If you cant borrow one that is) Its gonna be covered by the carpet anyways... Just make it as nice and straight as possible
Old 08-18-2010, 09:56 PM
  #27
HT White Ops
BlackDeuceCoupe's Avatar
Originally Posted by dtran
Anyone know where i can get the trunk bed thing for a 2000 ek? It's missing and it's just fabric in the back.
How about this?
96-00 Honda Civic Spare Tire Cover Trunk Board HB Hatch (eBay Motors)
$25 + $25 shipping...
Here's OEM:
84521-S00-A00 -- Lid, Spare Tire (Majestic Honda)
$38 + $13 shipping...
Old 08-18-2010, 11:07 PM
  #28
Kidnkorner's Avatar
how would we make a template?
Find someone that will let you trace theirs
Old 09-17-2010, 12:53 AM
  #29
H-T White Ops
NOFX's Avatar
I couldn't find this image when I saw this thread, but just found the image again and remembered your questions.
Here is a photo, along with measurements, of my stock '98 Civic coupe trunk board. This would be the same shape for any '96-'00 Civic coupe or sedan.
I don't immediately have the measurements for a hatch here, but here is an image of a hatch trunk board (from the eBay link above).
I have personally taken a '96-'00 Civic coupe trunk board and cut it to fit perfectly into a '96-'00 Civic hatch. So if you have a hatch and find a '96-'00 coupe or sedan trunk board, you can make one to fit the hatch out of that. Just cut the front of the board off.
(Front of vehicle is at the BOTTOM of the image for this pic.)
Old 09-17-2010, 02:32 AM
  #30
Ek Forever y0!
Libertariat's Avatar
Aye. Just borrow one if you can and trace it onto 1/4" plywood.
Old 09-17-2010, 07:45 AM
  #31
Jimster480's Avatar
This is what I did, I went to the local home depot, after measuring my trunk, and bought a huge board and cut it into 3 pieces that fit into the trunk. So now as they crack or get warped (my trunk leaks a bit) I just replace them. It cost me about $12 for that huge piece, and the pieces have lasted me over 2 years now. So I recommend doing that.
Old 09-17-2010, 07:53 AM
  #32
D Griff's Avatar
I would also just recommend cutting one yourself from plywood, the OEM ones are not very high quality. The cardboard/particle board stuff they're made of isn't very sturdy.
Old 09-17-2010, 10:03 AM
  #33
H-T White Ops
NOFX's Avatar
According to 94EG8, the material the stock trunk boards are made out of is called masonite.
There has to be something similiar (smooth and lightweight), but stronger.
Old 05-11-2011, 05:48 AM
  #34
a.e.m.'s Avatar
does anybody have measurements for an eg trunk lid?
Old 05-11-2011, 06:47 AM
  #35
JayDeeMmm's Avatar
use cardboard. thats what i did.
Old 05-11-2011, 06:48 AM
  #36
JayDeeMmm's Avatar
well for the template, then i used the pressed board i got at the lumber yard
Old 05-11-2011, 06:50 AM
  #37
JayDeeMmm's Avatar
i believe i started with a 4ft by 2ft piece of pressed board
Old 05-11-2011, 07:03 AM
  #38
alphalanos's Avatar
MDF. medium density fiberboard. make a cardboard template, I made it so it fits snug against the edges like that pic above, but I didnt make the little openings, just a flat peice that lays on the floor. You might need to make it in 2 peices depending on how much room there is to fit the peices in the car. Then cover it in carpet, it looks really nice and is super strong. I used 3/4 because I was planning on putting a sub box in but never did, you could go with 1/2 or maybe even 1/4 depending whats going on top of it.
Old 05-11-2011, 12:01 PM
  #39
cheggie's Avatar
Or, you can make your own lid out of plywood, and modify it to accomodate a full sized spare. I did this for my 96 EX
It doesn't sit perfectly flat, but it's damn close. I live in the country and commute 35 miles into the city, stuff happens. The retainer for the mini spare will hold the full sized deal if you just flip it over. I used what was left of the original masonite to cut a cover for the center - it's a place to store the tools, a poncho and a small electric air compressor.
Old 12-05-2013, 03:48 PM
  #40
jamesr's Avatar
bumpppp,
anyone know where I could find the carpet that stretched over the cardboard piece and goes over the back seats?
Old 12-05-2013, 04:14 PM
  #41
Jdm_em1civic's Avatar
Wow I was just dealing with this today.
So I couldnt find nothing the same to replace, so I hit up lowes and picked up the thinnest piece of plywood I could find. Cut, measure and BAM!
Fits perfectly so it works too
Old 12-05-2013, 06:37 PM
  #42
Laughing Man's Avatar
I did the 1/4" plywood using the oem carpet for a template in my trunk.
musicminister18
02-10-2014 01:01 PM
quick108
Honda S2000
07-18-2003 04:13 AM
Quick Reply: Where can I get a pressed wood cover under trunk floor mat for an 00 Civic?
