Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2001 - 2005)
Old 08-14-2010, 10:10 AM   #1
jmacc8
Default GETTING HOT WHILE IDLING
I have a 2001 honda civic that continues to get hot when i am sitting and idling for more then 3 minutes or so. Then when I rev the motor or start to drive down the road the temperature will return to normal. I replaced the thermostat but it still has the same problem, although since I replaced the thermostat it seems to not get hot as fast as it used to. I am thinking maybe I got a defective thermostat or possibly the water pump is out. Just wondering if anyone else has encountered a similar problem.
Thanks
jmacc8 is offline   Reply With Quote
Old 08-14-2010, 03:15 PM   #2
Pothole987
Pothole987's Avatar
Default Re: GETTING HOT WHILE IDLING
Any Cels? is your fan working?
2007 Honda civic SI White 2dr 6 speed
2007 Honda civic Brown 4dr 5 speed
2011 Chevorlet Silverado Black Cheyenne Edition 4WD
Pothole987 is offline   Reply With Quote
Old 08-14-2010, 04:30 PM   #3
Hollywood_Cal
water pump,fans,head gasket, temperature sensor,radiator flush or more who knows..
HOLLYWOOD CAL
Hollywood_Cal is offline   Reply With Quote
Old 08-14-2010, 06:45 PM   #4
jdmfreak1992
jdmfreak1992's Avatar
Did try burping your rad? Is the fan coming on, if not check the relay?
jdmfreak1992 is offline   Reply With Quote
Old 08-19-2010, 03:33 PM   #5
AutoXer
2004 Volkswagen R32
My Garage
AutoXer's Avatar
Usually when the car gets hot when sitting, and cools off when driving, it's a fan issue.
Check if it turns on when sitting and getting hot. If not, there's your problem. I had the fuse go on mine once.
AutoXer is offline   Reply With Quote
Old 08-19-2010, 03:38 PM   #6
ballisticej1
ballisticej1's Avatar
Check fan(s) if they're good then its a head gasket.
~400 whp ej1 in progress.
ballisticej1 is offline   Reply With Quote
Old 08-19-2010, 04:54 PM   #7
theineffable
theineffable's Avatar
did you change your coolant recently? try burping the air out?
i would say water pump but the OEM water pump has metal fins so i don't think there's a problem w/ broken fins...
theineffable is offline   Reply With Quote
Old 08-19-2010, 05:21 PM   #8
CRX Si69
1989 Honda Accord
CRX Si69's Avatar
your thermostat isnt opening.
CRX Si69 is offline   Reply With Quote
Old 08-20-2010, 11:52 AM   #9
2002-dxsedan
i've got an '02 d17a1, same problem, just needed to top up coolant cause i've got a leaky head gasket. i'm getting oil in my coolant res but have'nt seen any coolant in my oil
2002-dxsedan is offline   Reply With Quote
06, 2002, 2005, accord, burping, car, caused, civic, cools, driving, fan, honda, hot, idling, integra, motorcycle, radiator, runs, working
