rear disk
Re: rear disk
ya look for any from a 90-01 integra.
also if you were wondering, the integra hatch e-brake cables fit perfect, dunno if the sedans are the same but you could check if you felt the need. lol.
Re: rear disk
this thread will answer all your questions,if it doesn't.It's obvious your not reading then.https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rear-disk-brake-conversion-w-pics-1916212/
MC=Master Cylinder
BB=Brake Booster
Prop valve=Proportioning valve
MC=Master Cylinder
BB=Brake Booster
Re: rear disk
technically you dont need the brake booster. i just did rear discs on mine and did the prop valve only and it stops perfectly fine. i could see getting the brake booster if you upgrade the front breaks as well.
Re: rear disk
yeah Technically, but you need it to bolt up the DA master cylinder.since the MC ain't gonna bolt up correctly(different flange angle)to your stock booster.Plus your not gonna feel a difference in braking til you get the 15/16 Master cylinder.
Re: rear disk
well thats what i meant was the master cylinder and brake booster lol.
but that makes sense, i need to get on that ish for mine ASAP. thanks for the heads up dood.
Re: rear disk
I'm pretty sure it won't work. The first gen Teg which shares the same suspension as the 84-87 CRX (3G) had solid beam rear axles. The newer Civics (4G and up) have independent rear suspension.
Re: rear disk
http://www.fourthgenhatch.net/reardiscswap.html Use this write-up. Great info. Tell's you everything you need to do it and every single step down to the tee. I'll be following this tomorrow and I know it'll be easy doing so with this write as a few of my buddies have done it with this write up. GL.
Re: rear disk
As mentioned earlier, you need the 90-01 Integra rear disc brakes. I would get all the components together and install them all at once because bleeding brakes is not fun.
Re: rear disk
Im about to do mine today just found an almost complete 91 integra for parts. thanks for that great write up Fo-Do Fanatic that will help out a lot.
civic89si666
03-03-2007 07:33 PM
sick90hatch
05-06-2004 12:53 AM
