89 crx engine swap sohc to dohc cz
Old 08-08-2010, 01:35 PM
brendanailer's Avatar
Icon2 89 crx engine swap sohc to dohc cz
Completed engine swap 89 crx 1.5 to a 1.6 cz ,wont start no spark .Dist is off the si engine, vehicle retained its harnes and I have done the ecu mods as perscribed but do not have wire pairing for the dist as both plugs were cut also does not have connector c217 from shock tower to is this circuit required to get car to start ? Ecu is coding 6. HELP I AM going nuts.........
Old 08-08-2010, 04:49 PM
92civic4door's Avatar
Default Re: 89 crx engine swap sohc to dohc cz
the dizzy off the 1.5 si engine will not work on the 1.6L ZC you need the dizzy from the zc i just went thourgh all this on my CRX.
Old 08-08-2010, 05:54 PM
gRim06's Avatar
The 1. 5 isn't the si motor...the si distributor is from the 1.6 l sohc
Neither will work...you need the distributor from 89 integra and if you can the ecu as well
As well as more...this is all in the FAQ
Old 08-10-2010, 01:08 PM
The engine is a cz out of a si i kept thr dist that was in the engine and the wire harnes what i dont find is the pig tail for c-212 to the ecu. something is wierd the wires are at the pins on the ecu but they dont ring out per the drawing i have and the ecu codes 6 i am confused (wires from sensors to c212 no wires from c212 to ecu wires at ecu and seem to be the rire colors where are they going and i still have no spark and believe i have wired the dist rite with the exception of the ignitor *White) wire which started this c212 connector fubar
Old 08-10-2010, 01:10 PM
89ef9-87starion's Avatar
si has a d16a6 not a "cz" i think your talking about a dohc ZC?
Old 08-10-2010, 01:11 PM
Icon3 Re: 89 crx engine swap sohc to dohc cz
What is a dizzy ? I need a drink
Old 08-10-2010, 01:16 PM
distributer "dizzy"
crx2010
13
10-16-2015 10:26 AM
crsgrge
13
10-14-2014 04:52 PM
JScott3d
10
05-09-2010 08:25 PM
bird00420
04-12-2007 10:56 AM
Desert_Rex
01-05-2005 03:53 PM
Quick Reply: 89 crx engine swap sohc to dohc cz
