Can I use b20 cams on an ls head?
Old 07-27-2010, 04:26 PM
raidacaipo's Avatar
Default Can I use b20 cams on an ls head?
I have a b20z block and the head is gone. I decided to switch the head with an ls head however, I switch over the b20 cams, cam caps/holders, and rocker arms over to the ls head. Is this going to work? I haven't started the motor up yet. Do I need to use ls cam caps and rocker arms for the ls head?
Old 07-27-2010, 04:57 PM
nus_dogg's Avatar
Default Re: Can I use b20 cams on an ls head?
I don't see why not when people can actually put in LS cams into B16 heads. But I'm not sure how it will affect your performance though.
Old 07-27-2010, 05:40 PM
DVDr's Avatar
YES, you can switch over anything from the LS head to the B20 head . They are the same and fully interchangeable.
Old 07-27-2010, 05:42 PM
DVDr's Avatar
This is totally FALSE, you CANNOT put LS cams into a Vtec head. or vice-versa .
b16,b18c1,b18c5 head internals are all interchangeable . but not with b18a,b18b,b20.
Old 07-27-2010, 05:54 PM
raidacaipo's Avatar
well I know for sure you can swap cams but what about the head internals? like rocker arms, cam cap/holders?? The thing is that everything is already swapped over. The problem is that it seems as though the cam caps/holders are super tight when I torque it down, to the point that the cams aren't even able to move.
I tried moving the cam gears so that the pointers are set at TDC because I was also changing the timing belt. However, it seem as though the cam and the gears wouldn't budge at all! I mean how is the belt suppose to move it if I can't even turn it myself? Is that normal?
Old 07-28-2010, 05:20 AM
per4mance's Avatar
Dumbest response of the years awars goes to this jack-***. Stay away from cars bro, you have no idea whats going on.
Old 07-28-2010, 07:57 AM
oskrB18's Avatar
you must keep complete the LS head
Old 07-28-2010, 08:05 AM
Str8EJ's Avatar
You can NOT use the cam caps from one head on another. These parts are specific to each individual head and can not be interchanged, as you've discovered with the binding. Use the original caps.
You should not have any issues with rocker arms or camshafts, so long as they're in good condition and don't have any abnormal wear.
Old 07-28-2010, 11:34 AM
raidacaipo's Avatar
Thanks man.. thats all I wanted to know
Old 07-28-2010, 05:36 PM
dntnedvtec's Avatar
how long have you been around???JUst to let you know, your quote is now my signature...LOL....LS cams in a b16.....
OP, it will work. I am running 00 p-75 parts in my P8R head.
Old 07-28-2010, 08:49 PM
raidacaipo's Avatar
Even the cam caps from the p75??
Old 08-04-2010, 08:43 AM
Str8EJ's Avatar
No, no, no. Cam caps should not be switched.
Old 09-13-2010, 06:30 PM
dntnedvtec's Avatar
yes, even the cam caps. SO far, no issues at all. I am also using the cams, valve springs, and retainers.
integraracer157
01-05-2006 06:05 PM
SCIVIC94
03-03-2005 06:57 PM
jdm92teg
02-24-2005 12:23 PM
J-Spec EG
05-07-2004 09:38 PM
Quick Reply: Can I use b20 cams on an ls head?
