Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 07-14-2010, 09:08 PM   #1
90ED6LSV
90ED6LSV's Avatar
Default Weird scraping/grinding noise when turning right
It makes a noise that sounds like my brakes are scratching when i turn right and go over bumps. (driver side) It's mostly the bumps that make it do that. It will do it when going straight sometimes over bumps. But never turning left.
Wheel bearing? and ideas?
Buttonwillow CW13 - 2:13 Stock B16A
Famoso Raceway - 13.4 @ 105mph (B18A-t)
90ED6LSV is offline   Reply With Quote
Old 07-14-2010, 09:35 PM   #2
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
iTrader Rating: (1)
Default Re: Weird scraping/grinding noise when turning right
does it get worse when extra weight is in the car...!!!
BiG ChOr!Zo'S Garage Sale Thread v.2<--click me
BiG ChOr!Zo is offline   Reply With Quote
Old 07-14-2010, 09:42 PM   #3
Catfish4748
Catfish4748's Avatar
b
Catfish4748 is offline   Reply With Quote
Old 07-15-2010, 05:11 AM   #4
jlk16188
jlk16188's Avatar
Send a message via AIM to jlk16188
check to make sure the metal dust shield on the brake isnt rubbing on the rotor. Ive seen them rusted so bad that it broke off and wedged itself between the rotor and the back of the caliper. Sounded like a freight train driving down the road
jlk16188 is offline   Reply With Quote
Old 07-15-2010, 09:56 AM   #5
TJChad
TJChad's Avatar
wheel bearing is starting to go. Look up a at a recent post about a loud noise...
My project 88 crx si drag/street----->http://www.honda-tech.com/showthread.php?t=2800664
PART OUT THREAD--------->http://www.hondamarketplace.com/show....php?t=2951398
TJChad is offline   Reply With Quote
Old 07-15-2010, 10:19 AM   #6
91GEDHATCH
1990 Honda CRX
My Garage
91GEDHATCH's Avatar
steffenwade shivringknives steffenwade Dogdog54
Send a message via Skype™ to 91GEDHATCH
I have the same thing. I'm assuming you have a ls swap from your name, if so, did you happen to change out an axle? I just did and forgot to take the o ring that sits up against the bearing off. I guess they don't fit the ef, just throwing it out there.
91GEDHATCH is offline   Reply With Quote
Old 07-15-2010, 10:36 AM   #7
BiG ChOr!Zo
iTrader Rating: (1)
freight trains dont sound like that...its more like a stuck hand brake that someone forgot to take off
Old 07-15-2010, 02:26 PM   #8
90efhatchic
most likely a dust shield, does it sound metallic? wheel bearings will make a noise that picks up with speed and will do it straight on smooth roads doesnt need to turn or go over bumps to hear it... dust shields are common to get bent close enough to the rotor that turning and bumps will cause them to hit the road and grind but its sounds like thin pieces of metal not like if you where to take a grinder to a piece of rebar
90efhatchic is offline   Reply With Quote
Old 09-09-2011, 08:15 AM   #9
90ED6LSV
90ED6LSV's Avatar
sorry never replied, it's the crank pulley grinding on the radius arm for the front subframe. it happens on big bumps and hard turns. I think it's because I had eBay mounts, mounted the engine too low, i have Hasport mounts in now and it hasn't done it again.
dragging, grinding, grinds, honda, left, noise, odyssey, pilot, rear, rubbing, s2000, tech, turn, turning, wheel
