Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Element & CR-V
Old 07-12-2010, 11:57 AM   #1
Charlie Moua
Charlie Moua's Avatar
iTrader Rating: (3)
Default 2000 crv - rear differential fluid?
Okay the rear diff is starting to make some noise, so I figured it's time to change out the fluid. What kind of fluid can I use?
OEM - lucas - any gear oil at autozone?
how many quarts will I need to fill it up?
Thanks - Charlie
Jordan Tuned ~ MAPerformance ~ Progress Technology ~ CNC Werx
phearable.net ~ SpeedTrap Turbo Consulting ~ 4piston ~ Rocket Motorsports/P.R.E.
VOUCH
Charlie Moua is offline   Reply With Quote
Old 07-12-2010, 12:24 PM   #2
eghatch4sale
eghatch4sale's Avatar
Send a message via AIM to eghatch4sale
Default Re: 2000 crv - rear differential fluid?
i would just go to the dealer for it i think it was dual pump 8.50 a quart
eghatch4sale is offline   Reply With Quote
Old 07-12-2010, 05:51 PM   #3
Duane_in_Japan
Duane_in_Japan's Avatar
It may be like gear lube, it may be like tranny fluid viscosity, get it from the dealer and some additive also, stabilizer of some sort for older diffs. Inspect for leaks, clean them up and be prepared for a regular inspection and refill if you have a leak.
Duane in Japan, sonataauto uses Hotmail
Tools to do the job, Training in the skills necessary to be more effective, Technology to be efficient and maximize the time spent, Support the efforts and challenges the business and staff face daily.
Duane_in_Japan is offline   Reply With Quote
Old 07-17-2010, 06:16 PM   #4
oroblram
oroblram's Avatar
oem dual pump 2 is good and quiet.
oroblram is offline   Reply With Quote
Old 07-17-2010, 09:12 PM   #5
qwrty
qwrty's Avatar
use OEM fluids....
itll save you time and hassles in the future!
.....under pressure
" taking/moving the other "side" of the [H]onda game......... "
qwrty is offline   Reply With Quote
Old 07-17-2010, 10:34 PM   #6
Sordz
Sordz's Avatar
Send a message via AIM to Sordz
Like everyone else said, OEM fluid for sure, buy 2 quarts it takes just over 1 to drain and fill. You should change it more often than what it sounds like you do, same with valve adjustment. Good luck
Sordz is offline   Reply With Quote
Old 07-17-2010, 10:57 PM   #7
Duane_in_Japan
Sordz, you have reached a milestone in your H-T post history, 69 posts, its time for you to upgrade to a real avatar and get rid of that noob looking thing there toughguy.
Old 09-09-2010, 06:50 PM   #8
johncrash
johncrash's Avatar
dual pump is the fix if real bad you might have to do ittwice
johncrash is offline   Reply With Quote
2000, 2002, 2010, crv, differential, fluid, forum, honda, insight, leak, noise, oil, rear, replace, s2000
