Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
97 ACURA 3.2TL, OVERHEATING
Old 07-10-2010, 10:21 AM
hdvolksda91's Avatar
Default 97 ACURA 3.2TL, OVERHEATING
hi, i have a 1997 Acura 3.2TL that is having some bad overheating problems. I've replaced Radiator, radiator cap, thermostat, and upper rad hose. its eating/burning coolant. No missfires. no moisture on oil cap. is this a common problem ?
Old 12-03-2011, 05:11 PM
waymlee87's Avatar
Default Re: 97 ACURA 3.2TL, OVERHEATING
I have the same problem as you do. Apparently I can't find any answers anywhere else and no one has replied to your posting either.
Old 12-04-2011, 09:03 AM
civichxtreme2's Avatar
How many miles are both of you looking at? The head gaskets tend to go on these things with decent mileage. Check your coolant for oil and vice versa, also may want to do a compression test and leakdown test, I would bet money that is both of your problems, Its semi-common on First Gen TL's
Old 12-14-2011, 06:45 AM
georgeswan33's Avatar
Had the same issue, went to the shop for tests, after the compression test and leakdown test changed the head gaskets and now all is okay.
Old 01-15-2012, 09:01 PM
Mikifin's Avatar
I am having the same problem
It is fine while driving on the freeway, but when I am sitting in traffic it gets real hot. There are no leaks I have already replaced the coolant temperature iensor.
It has just over 120,000 miles on it.
Old 01-16-2012, 12:20 PM
MEAT PATTY
goforbroke's Avatar
It sounds like it's your headgasket. Do a compression test.
Old 01-17-2012, 11:44 AM
Canadian144's Avatar
BHG. Extremely common on the C32A engines.
Old 01-19-2012, 01:41 PM
Mikifin's Avatar
I don't have the ability to do a compression test at the moment. I just moved 2500 miles and most of my tools are in storage. I did just change the spark plugs and they were all incredibly clean. I am not leaking any coolant and the oil is clean. I am thinking possibly the radiator fan switch at the bottom of the radiator.
Old 02-10-2012, 04:36 PM
ratrace2's Avatar
Check the fans and see if they turn on at all.....
ALso, take of the radiator cap and watch for any water shooting out of the radiator. If it does, then you have a blown head gaskets.......
Old 04-24-2012, 04:04 PM
dava411's Avatar
My Acura 3.2TL has been overheating we did the compression test and everything was good, changed the water pump, thermostat, had the heater core checked, changed the radiator cap, checked the fan relays out, checked every hose attached no collapsing hoses, finally we changed the ECT switch, We ended up having to change the head gasket, The shop we took it to said for $1700 they would change it for us. We changed it, it cost us, $600+ and everywhere we read on it said CHANGE the water pump timing belt, thermostat and ECT sensor just to be on the safe side, otherwise you may be doing it again in around 5 or 6000 miles!! So total price was total 674.00 plus 12 hours + under the hood!!
d16trexin
27
01-27-2015 07:08 AM
DelSolDon
09-22-2008 04:24 PM
HellerDopeEK4
02-21-2008 03:52 PM
b00sted4dr
10-12-2006 10:19 PM
dualknuttz1
08-18-2003 10:57 PM
Quick Reply: 97 ACURA 3.2TL, OVERHEATING
