Closed Thread
Old 07-07-2010, 06:09 PM   #1
nieto1991
Default Best High Flow Cat for an EM1?
Whats the best High Flow Cat for an EM1?
Please lmk,
nieto1991 is offline
Old 07-07-2010, 06:16 PM   #2
robfrmny21
robfrmny21's Avatar
Default Re: Best High Flow Cat for an EM1?
GET TEST PIPE NUFF SAID
OIL=VTEC JUICE
robfrmny21 is offline
Old 07-07-2010, 06:19 PM   #3
nieto1991
i was thinking of that but i dont like it be overly loud since im useing my car as a dd
Old 07-07-2010, 11:13 PM   #4
Ruben19
Ruben19's Avatar
Send a message via ICQ to Ruben19 Send a message via AIM to Ruben19
do u have a loud exhaust or something?
Middle finger to All Thieves here in WA and over the world, they deserve to die now
Em1 crew Peyton Manning #18 Best QB in the NFL. I <3 HATERS
Ruben19 is offline
Old 07-08-2010, 01:13 AM   #5
chewyv
pm4nudes
chewyv's Avatar
NOT A TARGET
nothing wrong with oem
chewyv is offline
Old 07-08-2010, 01:33 AM   #6
Deetz
2000 Honda Civic
My Garage
Deetz's Avatar
What's funny about this thread is that either removing the cat (terrible idea) or running a high flow cat, you will gain maybe 2hp, LOL
If you are just looking to replace yours because it's clogged or damaged, Magnaflow sells them fairly cheap. I needed a new one for my EM1, and ended up just sourcing out a perfect condition Integra cat for next to nothing
Deetz is online now
Old 07-08-2010, 02:04 AM   #7
BlackDeuceCoupe
HT White Ops
BlackDeuceCoupe's Avatar
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Originally Posted by Deetz View Post
If you are just looking to replace yours because it's clogged or damaged, Magnaflow sells them fairly cheap.[...]
I'm super happy with the Magnaflow on my B16A2!
EM1 cats cost more than generic cats, because the 02 bung is located in the middle (only measures 1st half of cat). It's kind of an oddball.
I bought mine on Amazon.com: MagnaFlow 22630 Direct Fit Catalytic Converter - 49 state Legal ($194 +FS)
I looked all over the web, and everyone gets about the same price. My local Honda dealer wanted $670 for an OEM cat ($820 List). LoL!
ODB2 is picky, and I was tired of throwing CELs (blew out my OEM cat when I lost a dissy)! Personally, I didn't want to mess around with cutting, bending, and welding the pipes, just to save 50 bucks...
This cat is great! Sounds good, smells good, looks good, integrated heat shield, bolt-on installation, and the price is right.
Did I say, "smells good?" OMG, my B16 smelled dank after the cat blew!!! I drove it that way for a few days (and triggered a CEL every day) waiting for the Magnaflow to arrive. There's NO f**king way I would drive a DD on a test pipe!
BTW, if you get one of these, you'll need a new metal (crush) gasket on the exhaust (b-pipe) side. It was around 4 bucks at the dealer. Regular auto parts stores don't stock them. I reused the tapered (flex) gasket on the a-pipe side (header to cat).
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who failed. They know what they're talking about... not!
BlackDeuceCoupe is offline
Old 07-08-2010, 07:49 AM   #8
nieto1991
Im not tryng to remove it. I just need a new one because i had my car too low and tore up pretty bad
Old 07-08-2010, 08:00 AM   #9
nieto1991
Thanks Sir
Ima be looking into probably buying the Magnaflow 22630
Did you have to get a tune or anyting so i can run properly?
I was reading under their page and it said "Engine Tune-Up Required"
Old 07-08-2010, 08:04 AM   #10
nieto1991
Nope my cat tore up from my car being to low. i have an axle back exhaust, nothing big or loud at all
Old 07-08-2010, 08:07 AM   #11
JKov240
1994 Honda Civic
JKov240's Avatar
Send a message via AIM to JKov240
I made the mistake of removing my cat for a test pipe on my old '94 Civic hatch that had a B18C1 swap. If the sound isn't annoying enough, the exhaust fumes will be eventually.
I ended up putting a Magnaflow high-flow cat on it....it actually made the exhaust deeper and better sounding IMO...AND took care of the fumes.
JKov240 is offline
Old 07-08-2010, 08:08 AM   #12
nieto1991
What kind did you get? an where you buy it?
Old 07-08-2010, 08:12 AM   #13
JKov240
1994 Honda Civic
JKov240's Avatar
If I remember correctly (it's been a few years haha), I got one of the universal ones off of eBay. The seller/store I bought it from had the dimensions, so I made sure it would fit length/width wise, and piping wise (my exhaust was 2.25" piping).
After that, I took it to one of my friend's shops that has a welder and had them cut the proper amount of piping out of the old test pipe, and welded the new cat in...but I'm sure any exhaust/muffler shop would be willing to take care of it for you for not too much.
I'm trying to remember though.....on EM1s the cat is under the car and NOT on the exhaust manifold itself, right?
JKov240 is offline
Old 07-08-2010, 08:16 AM   #14
nieto1991
That right their right under the car not hooked on the manifold
Old 07-08-2010, 08:47 AM   #15
JKov240
1994 Honda Civic
JKov240's Avatar
If they make a specific one for EM1s, then get that...if not, just make sure a universal one will fit properly.
As far as it being OBD2, you may need to get one of the O2 simulators so that the CEL will stay off.
JKov240 is offline
Old 07-17-2010, 12:29 PM   #16
nieto1991
got a hold of good condition stock cat so im just going to replace it
Old 07-17-2010, 01:40 PM   #17
apexi_rsx
Send a message via AIM to apexi_rsx
randomtechnology.com direct bolt ons
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline
Closed Thread
auto, best, bronx, buy, cat, flow, high, hight, honda, ny, pipe, prelude, regular, store, test, type
