Speedometer guage
Speedometer guage
Hi,
I have recently notice that my 2000 civic si speedometer guage is bouncing around from time to time and then it will settle down after a while. The alternator was replace by Honda in 2008 of March, so I was wondering if it might be the speed sensor.?? I wonder what you guy's think it might be. any help will be appreciated thanks...
Re: Speedometer guage
Does the odometer and trip counter still work? I have the same problem. My VSS completely stopped working, saw the plug was corroded, wired up a new plug and now it does the same the just the odometer works now. Check for a break in a wire.
my money is on the cluster. just cause you didn't tamper with it doesn't mean it won't fail. they have a tendency do so unfortunately. if you don't have a cel for vss and your cruise control (assuming you have it) still works, then i'm definitely thinking the cluster itself is bad.
The Odometer works and the trip meter works as well.
For what it's worth, no codes were thrown when the speedometer stop working on my son's 92 Civic. Replaced the VSS anyway and that fixed the problem. I've read of other cases, as well, where a bad VSS did not throw a code. Not sure why that is, but apparently it happens.
this further makes me believe that the cluster is at fault. if it was the vss you would have a cel on for it, cruise control would not work, and your odometer/trip would not function.
So because a dude who probably doesn't even drive a Honda tell you that the cluster is perfect, without him ever seeing it, or you even knowing if it's perfect, guarantees it's perfect? Bullcrap. You'll trust a dude fresh out of HS auto body then a forum full of savvy Honda owners? This is bad troubleshooting. But go ahead, waste $200+ on a VSS and be wrong. I'll sit here and laugh.
i brought up the part about cruise control because if it works then that means you are still getting a good vss signal. the speedometer just isn't displaying it.
through Honda will be obnoxiously expensive i'd bet. if that's the case then you might consider picking one up through eBay. em1 clusters typically go for $350-$400.
it will be a good choice to look on ebay, the only problem with that is that they all used and you not sure what you getting, where as with new from honda you know what you getting . The cluster is something i might want to buy new so there is no problems and your money is not wasted. the used one you might have the same problem and there is no refund.
if you're smart about who you're buying from and read the listing carefully then you shouldn't have any trouble. if somebody dicks you over, then that's what the feedback system and paypal protection is for. now, if the cluster through Honda is only slightly more expensive then used on eBay then i'd probably just grab a new one. if the price however is much greater then i'd likely by a used one. that's just my thought on it anyway.
I'd like to do the process of elimination without buying two new parts awhen I only needed one, but if you like spending money, fine. I'm just saying, your thought process was very wrong. Honda dudes that work at the counter don't know everything bro.
Hi,
Like I have mention to others here on this thread, It can't be my Speed odometer being bad. I have replace the Speed Sensor and that have fix my problem with the speed gauge bouncing around. So for those who have the same issue please do not go and spend big money to buy a Cluster as it may not fix your problem. Start with the cheapest part first and that is go to the Advance Auto Store and have them put the digital tester on the battery and test for the Alternator and starter and battery load and see if that all is ok, if so then you may want to try a friend speed sensor on your car providing its the same as yours or just buy a new speed sensor, if not then you start checking the wiring behind the cluster and the grounds on the Transmission. Good luck to all who have help in this thread and Thank you all for the info.
The answer to my fix was the speed sensor which cost $68.00 new, and my Speed Odometer is working like it should. Thank god I did not buy a cluster for $200.00 from ebay like others said here, it would of been a waste of money.....
good to read this, I am trying to work out this same problem on my 94 civic, and will definitely buy a new VSS before getting into the wire checking...
Take the cluster out and get to the circuit board on the back of the speedo. There you will see a bunch of solder points, as the solder ages it sometimes cracks and leaves a bad connection. Take a soldering iron and heat the solder on each one of the points on the circuit board for the speedo. You might have to add some solder to some of them. I did this in my 95 accord and it took care of the problem. That is as long as your not throwing a speed sensor code.
