My 92 Civic VX is having problem need help please,.
Old 07-13-2010, 07:53 AM
  #26
Oh look, I can change this
deschlong's Avatar
Default Re: My 92 Civic VX is having problem need help please,.
+1 to RonJ for being so incredibly helpful in this thread (and many many others).
Old 07-13-2010, 09:41 AM
  #27
LoGaN-VanG's Avatar
Originally Posted by RonJ@HT
Did you jump the service connector and adjust the ignition timing to spec with a timing gun after replacing the distributor?
Yes, I just did... I use the gun. Everything looks right... hmm,... it still lags,...
Old 07-13-2010, 10:01 AM
  #28
Former User's Avatar
Did the pointer on the lower timing belt cover align perfectly with the red mark (middle in group of three) on the crank pulley?
Old 07-13-2010, 10:21 AM
  #29
LoGaN-VanG's Avatar
hmm,... that might be right... I think is off, let me check.
Old 07-15-2010, 07:32 AM
  #30
LoGaN-VanG's Avatar
I'm lost I been messing with the timing, and now it seem like it's all F*ck up! I'm confuse, but here's what I got when the car run, I check it with the timing gun, it's at the Red mark, in between the 3 mark which is the red mark I believe, and while the car is off, I check and it's at the white mark, TDC... is this right or am I way off? thanks
Old 07-15-2010, 08:23 AM
  #31
Both the ignition timing and mechanical timing are fine. The red mark is for the ignition timing whereas the white mark is for the mechanical timing.
Old 07-15-2010, 08:38 AM
  #32
LoGaN-VanG's Avatar
Well now that the timing is right, the car isn't laggy anymore, but now the car is joking when your holding on the speed limit at any speed, on the hwy or in the city, why is that? Sorry I know I ask for to much help but thanks, for your time.
Old 07-15-2010, 08:52 AM
  #33
Is it throwing any CEL codes? Are any dash warning lights on while driving?
Old 07-15-2010, 09:27 AM
  #34
LoGaN-VanG's Avatar
No, there's noting comes on the dish, no Check Light Engine hmm... Brand new distributor, cap, rotor, spark plug, spark plug wire.
Old 07-15-2010, 09:38 AM
  #35
Have you recently replace the fuel filter? You might also want to do a Seafoam engine treatment.
Old 07-15-2010, 09:59 AM
  #36
LoGaN-VanG's Avatar
Yeah I for got to listed, It's also brand new I just put in, the fuel filter...
Old 08-12-2010, 09:36 AM
  #37
LoGaN-VanG's Avatar
Here we are again,... Sorry for the late reply, I haven't have time to work on my car lately. It still lag on me, doesn't matter what gear I'm in, if 1st gear doesn't lag then 2nd and 3rd would, idk it's confusing me, have anyone ran into this problem lately? please help,...
Old 09-07-2010, 05:52 PM
  #38
hmong337's Avatar
hey man, i'm having the same problem too. though, i don't think mine is as severe. but i'm just **** about my cars and always need them to be running perfect.
my car does feel like it's hesitating at about 10% throttle under 2000rpms. i've done all my ignition components and still the same thing. so this is leading me to believe that the hesitation problem is fuel related. like you, i bought my car and let it sat for a year too. not good!
this weekend, i'm going to get a bottle of seafoam and run it through the car. after that, replace my fuel filter. i hope to resolve this slight hesitation problem i'm having as well.
Old 09-09-2010, 12:33 PM
  #39
deschlong's Avatar
IIRC, there *is* a noticeable lag somewhere in the mid-RPMs for the VX engine. This is due to entry/exit from lean burn mode. You'll find more information on this topic on boards that specialize in fuel economy vs. HT which is more for go-fast gear-heads. Of course, what you have might be abnormal, too - but just FYI that you can't get rid of it completely ... it's by design.
EDIT: If it is a problem, looks like ecomodder.com might have a few clues: http://www.google.com/search?q=civic...ient=firefox-a
bigbubbaseb
06-06-2013 01:22 PM
rohec04
09-15-2005 12:53 PM
EGhatched
14
11-19-2003 04:54 PM
Quick Reply: My 92 Civic VX is having problem need help please,.
