Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 09-14-2002, 02:21 PM   #1
TimsTeg
Default How to test for a bad CV joint? help....
I finally got my car running perfect and when i take left turns there is a clunking sound coming from the front end. I think it is the CV because it does it with the clutch in and with it out. It is only when i take left turns. Anybody know how to test to make sure it is the CV so i dont' waste more money?
91 Acura Integra
- freshly painted
- exedy organic clutch
89 CRX si - barbados yellow
- sold
92 Accord LX
- I/H/E
- 17" konig caffeines
- Kuhmo Ecsta Supra 712's
TimsTeg is offline   Reply With Quote
Old 09-14-2002, 02:32 PM   #2
PhatOptimo
PhatOptimo's Avatar
Default Re: How to test for a bad CV joint? help.... (Accord092)
If it knocks during turn its most likely the axle. You might feel a little odd vibration coming from there 2. You can also get under the car and look at the boots. If they are torn they need to be replaced. Its also a good idea to change them both at the same time. HTH
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
PhatOptimo is offline   Reply With Quote
Old 09-14-2002, 02:43 PM   #3
90-CRXSi
90-CRXSi's Avatar
Send a message via AIM to 90-CRXSi
Default Re: How to test for a bad CV joint? help.... (Phat_Optimo)
I have the same problem on only left turns. I have a b16 swap and it seems my cv joints are binding up when turn. I've taken it to like 3 local import shops who do swaps and they don't know why it is. Anyone have any idea.
90-CRXSi is offline   Reply With Quote
Old 09-14-2002, 03:40 PM   #4
SteveeeO
Default Re: How to test for a bad CV joint? help.... (90-CRXSi)
it's the axles ... did it to my car too, they wanted $400 LOL! so I said screw it and got a new car
SteveeeO is offline   Reply With Quote
Old 09-14-2002, 04:33 PM   #5
performula
performula's Avatar
Hold on. It's the CV joint or the axle?
When do you know to change the axle?
I graduated from Honda.
performula is offline   Reply With Quote
Old 09-14-2002, 04:49 PM   #6
Hcivic88
Hcivic88's Avatar
Default Re: How to test for a bad CV joint? help.... (performula)
i dont think you can replace just the joint, you have to replace the axle, theres a short one on the passengers side and a long one on the drivers side, they're not too hard to do, just did mine last week.
Jamie
1988 Honda Civic Hatch SE - DOHC ZC(for sale)
1994 Accord LX coupe(current driver)
- lowered on eibach pro's and kyb agx
My site w/ 4th gen tech info and how-to's
Hcivic88 is offline   Reply With Quote
Old 09-14-2002, 05:03 PM   #7
PhatOptimo
PhatOptimo's Avatar
Sorry, I should have been more clear. You are going to need to change the whole axle not just the boot. If the cv joint is knocking the axle must be changed. You know to change the axle when it make a noticable popping noise when you turn. Change both axles out at the same time even if only one is knocking/popping.
*EDIT* some shops will rebuild your axles for you but its gonna co$t.
[Modified by Phat_Optimo, 8:05 PM 9/14/2002]
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
Old 09-14-2002, 05:18 PM   #8
shortyz
Send a message via ICQ to shortyz
yeah change both axles. its easy.
shortyz is offline   Reply With Quote
Old 09-14-2002, 09:13 PM   #9
h8tred
h8tred's Avatar
Location: Commonwealth my ass This is the communist state, VA, USA
Send a message via AIM to h8tred
Default Re: How to test for a bad CV joint? help.... (shortyz)
Sounds like something is up with the axle its self to me... He said it does it when the clutch is in. If it were the cv, It would only do it when power is applied. Did you get new axles with your swap? Your stock axles will not work, I think the driver side is too long. Here is a link to a good write up on it... http://www.hasport.com/B16axles.htm
[Modified by h8tred, 1:13 AM 9/15/2002]
My babies:
1992 240SX SE Fastback
1991 240SX SE Fastback Hicas, and KA-T (Under the knife...)
1991 240sx SE Fastback Hicas, Canadian import.
1991 Civic Hatch
h8tred is offline   Reply With Quote
91, accord, axle, bad, binding, caused, check, civic, cv, joint, s2000, shaft, sounds, swap, test
