Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Classic Hondas
Old 06-20-2010, 06:56 PM   #1
rzecca
Default 1988 civic dx fuel pump issues
I have a 1988 civic dx 4 door sedan, 1.5L, I recently have been having trouble with the fuel pump? I figured it was bad as I was getting no fuel and the car would'nt start, will run with Gummout!,. I went ahead and replaced it(the fuel pump),... it still does not seem to pump fuel! I checked the old one with 12 volts and it works! Rats! 201$ out the window! The sevice manual says to check the main relay, located under dash, next to the fuse panel. There is a series of connecting terminals together and providing 12 volts to other terminals in a peticular sequence, it check out good, I'm only getting about 6 volts at the fuel pump/sending unit plug (access under rear seat)? Could my ECU be bad? I'm scratching my head on this one. any advise would be greatly apreciated!!
Thanks,
rzecca is offline   Reply With Quote
Old 06-21-2010, 06:11 PM   #2
Gabe87CRX
Gabe87CRX's Avatar
Default Re: 1988 civic dx fuel pump issues
Check the fuse in the fuse box labeled ALTERNATOR / SOLENOID, just had this problem...
87 CRX Si Worklog
Gabe87CRX is offline   Reply With Quote
1988, 90, accord, civic, common, dx, filter, fuel, fuse, honda, located, problems, pump, srx, working
