High pitch noise coming from engine.
Old 06-17-2010, 04:24 PM
JasonYo's Avatar
Icon3 High pitch noise coming from engine.
So when my engine is warm and only at idle it starts to make this high pitch whistling/squeaking noise. I know that it is not any of the belts or the intake. It is also not any of the vaccume hoses on the intake manifold.
Heres a video to see what it sounds like. You can hear it really well towards the end.
http://www.youtube.com/watch?v=VINMLaXpU4o
If anyone knows what it could be please help, it is the most annoying thing ever! And I cannot figure this out! Thanks.
Old 06-17-2010, 04:47 PM
_eg6_'s Avatar
Default Re: High pitch noise coming from engine.
man thats a tough one gl
Old 06-17-2010, 04:59 PM
JasonYo's Avatar
Ya I know lol. thanks.
Old 06-17-2010, 06:57 PM
Former User's Avatar
Sounds like a bad pulley bearing. Use an inexpensive engine stethoscope to pinpoint the noise.
Old 06-17-2010, 07:21 PM
JasonYo's Avatar
Alright I'll try to check those out.
Old 06-17-2010, 07:24 PM
b1u3_5i's Avatar
Also check your alternator. If you can, start eliminating a/c, altrernator, p/s belts one by one, and see if the sound goes away. I hope this helps.
Old 06-17-2010, 07:36 PM
JasonYo's Avatar
Well I don't have a/c, and I ran the engine with the alternator belt off so it's not that.
I might try disconnecting the p/s belt to see if its that.
Old 06-17-2010, 08:38 PM
itsmejto's Avatar
cheap stethoscope = piece of hose.
Old 06-18-2010, 07:28 AM
JasonYo's Avatar
Hmm yes, good idea!
I'll try to pinpoint the noise first, but I did listen very carefully for a while the other day and it seems to be coming from the cam pulley area or just behind. The noise is clearly not from the p/s area.
Is it possible that the timing belt is to tight or something?
Or could the pulleys be making this noise?
Old 06-18-2010, 09:27 AM
Atomic1's Avatar
Try squeezing your pcv hose when it's making the noise.
Old 06-18-2010, 09:32 AM
Hill4589's Avatar
Agreed. And I wanted to compliment you on how clean the engine bay is!
Old 06-18-2010, 10:04 AM
BrandonR's Avatar
Honestly, it sounds like air whistling as it goes through the IACV passages. If you notice it only whines when the IACV opens up. I had a 5.0 Mustang that did that, as well as many other 5.0's. Take off your IACV and sand the sharp edges down slightly.
Old 06-18-2010, 10:12 AM
blackKready's Avatar
yeah its definitely air. soon as you give it even the littlest throttle it goes away.
Old 06-18-2010, 01:32 PM
JasonYo's Avatar
I'll check the IACV, I was told it was a air leak or something for sure.
Old 06-18-2010, 01:34 PM
JasonYo's Avatar
Thanks! I try to keep it as clean as possible.
Old 06-18-2010, 01:36 PM
The locations of the sound and IACV aren't a good fit.
Old 06-18-2010, 01:49 PM
JasonYo's Avatar
Yeah, well the sound is more towards the rear drivers side of the engine. It's not at all near the tb. So it's probably not that.
Old 06-18-2010, 01:53 PM
Sounds like the alternator. As already mentioned, remove the alt belt to see if the sound goes away.
Old 06-18-2010, 09:27 PM
JasonYo's Avatar
Yeah I did that and the sound didn't go away!
A lot of people have been telling me that it sounds like a air leak, not bad bearings. I don't know tho.
Old 06-19-2010, 05:40 AM
JasonYo's Avatar
Someone said that it could be a intake valve leaking. Is this possible?
Old 06-19-2010, 06:05 AM
Seriously, I paid only $4 for an engine stethoscope at Harbor Freight Tools.
Old 06-19-2010, 02:14 PM
JasonYo's Avatar
Well I'll get one it's just that I work everyday except sunday and I can only work on my car at night. Stores are pretty much closed when I'm off.
I guess i'll just wait until then.
Old 07-15-2010, 02:13 PM
JasonYo's Avatar
Any more Ideas as to what this might be?
Still haven't figured it out, and don't have the time to do anything big like take my engine apart. =/
Old 07-16-2010, 10:16 AM
Dymond's Avatar
That's a clean *** engine bay
+1
Old 07-16-2010, 09:53 PM
JasonYo's Avatar
Thanks!
Quick Reply: High pitch noise coming from engine.
