Old 06-17-2010, 09:59 AM   #1
cyclonedr
Icon2 Replacing Valve Cover Gasket
Hello all,
I'm about to dive into the replacement of my 92 Accord's valve cover gasket and was wondering if there was anything I should know or do before I take everything apart. I bought a kit that has all the extra little gaskets and grommets and the like. Since the gasket is rubber, do I still need to use any RTV? If so where would I place it on the gasket. I have a tube of Ultra Black, but I've been told to use Ultra Grey on Honda's. Does it matter? What would be the best way to clean what little oil has leaked out off of the cylinder head? Thanks for any suggestions and have a great day.
Cyclone
cyclonedr is offline   Reply With Quote
Old 06-17-2010, 10:22 AM   #2
sgraham01
1994 Honda Accord
Default Re: Replacing Valve Cover Gasket
after removal of the valve cover, remove all traces of the old gasket, but don't scratch anything. once you have the old gasket off, clean the mating surfaces with solvent and let dry. install the 4 tube seals with a little silicone, install the new gasket into the groove in the cover so that it's in its final position, then lift one end at a time and apply silicone gasket to the inside corners of the gasket on each end. then apply some to the outside of the 4 corners and install on the head, torquing the nuts to spec. let it cure for a couple hours before running the engine.
1994 ACCORD LX
5-LUG SWAP, RSX WHEELS, EIBACH SPRINGS, SHAVED ANTENNA AND SIDE MOLDING
2000 GMC SONOMA-SHAVED AND BAGGED
sgraham01 is offline   Reply With Quote
Old 06-17-2010, 01:38 PM   #3
rodneylynn1977
1999 Honda Accord
Is there supposed to be a vaccume on the larger hose going from the valve cover to the intake?
rodneylynn1977 is offline   Reply With Quote
Old 06-17-2010, 05:15 PM   #4
sgraham01
1994 Honda Accord
the PCV valve in the valve cover grommet vents the crankcase back into the intake manifold. the vacuum in the intake manifold should be present in that hose.
1994 ACCORD LX
Old 06-17-2010, 08:33 PM   #5
rodneylynn1977
1999 Honda Accord
How much blowby should you feel from the oil cap when the car is running?
Old 06-18-2010, 03:30 AM   #6
sgraham01
1994 Honda Accord
I'm not sure I understand what you're asking, but you shouldn't have the oil cap off with engine running anyway. You will get oil spray through the filler hole.
1994 ACCORD LX
1994, 2002, accord, civic, clean, cover, gasket, grommets, honda, install, installing, lx, replace, replacing, tech, valve
