Old 06-16-2010, 10:30 AM   #1
mac_24_seven
1994 Acura Integra
mac_24_seven's Avatar
iTrader Rating: (1)
Default Ac Problem: Charge system and Freon shoots out AC pressure release valve.
94 Del Sol Si.. AKa: Jellybean
Just like the title says.. You can create a vaccum on the system (with the pump) then charge it with Freon. When you turn on the AC it will start to blow cold and then the Freon shoots out of the pressure release valve on the AC compressor.
What could be the problem aside from a blockage somewhere?
Any ideas?
mac_24_seven is offline   Reply With Quote
Old 06-16-2010, 10:48 AM   #2
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Default Re: Ac Problem: Charge system and Freon shoots out AC pressure release valve.
Does the condenser fan run?
Is the condenser clogged with bugs?
Also could be a clogged condenser or condenser line.
Don't guess, troubleshoot.
Old 06-16-2010, 11:04 AM   #3
mac_24_seven
1994 Acura Integra
iTrader Rating: (1)
Yes it does.
No, it's actually very clean.
I assume it is a clogged line somewhere but I'm no AC tech so it could be something else that I may not know about and somebody who knows more about AC system than me might
06, ac, air, blowing, charge, civic, conditioner, freon, honda, hondatech, mdx, pressure, release, system, valve
