Old 03-25-2015, 10:53 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
changing thermostat
Old 06-13-2010, 01:09 PM
redd357's Avatar
Default changing thermostat
Is the t-stat easy to change. My wife 2002 honda accord ex is overheating. I really dont want to take it to a mechanic if i could do it myself.
Old 06-13-2010, 01:16 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: changing thermostat
easy
http://www.autozone.com/autozone/rep...96b43f803751e1
Old 06-13-2010, 01:18 PM
ThatsMyEG's Avatar
yes it's very easy 2bolts and a couple hoses. Get the thermostat, the rubber gasket and some sealant. probably will cost less than 12 dollars for everything.
Old 06-13-2010, 02:18 PM
nus_dogg's Avatar
Did you correctly diagnose to blame the T-Stat though? What if it didn't fix the problem after you replaced the T-Stat?
Did you make sure that the passenger side fan(radiator fan) is working like it should? It could be a bad coolant sensor, radiator cap, fan motor, fan circuit + fuse, faulty radiator, etc.
But yes, the T-Stat is easy.
Old 06-14-2010, 08:03 AM
sgraham01's Avatar
If you do decide that the stat is bad and replace it yourself, place it in a small pot of water on the stove (without the seal on it- you could melt the seal if it touches the bottom of the pot) and boil the water to make sure the stat opens correctly before you install it.
Also, position the new one exactly like the stock one is positioned in the housing with the weep hole in the right place, at the top i believe.
Old 06-22-2010, 03:38 PM
redd357's Avatar
Thanks for all the help change out the t stat, every thing works fine. Now I just got to figure out how to keep my wife from trading paint on th I-410.
woob87
02-27-2018 04:28 AM
woob87
02-26-2018 10:30 PM
hmtcrxsir
04-29-2009 06:48 PM
rasinhell
05-24-2005 06:05 PM
hitop
01-16-2003 03:38 PM
Quick Reply: changing thermostat
