Old 06-09-2010, 10:43 AM   #1
KeepItSimpleJDM
KeepItSimpleJDM's Avatar
Default b20 vtec w/ GSR Head???
Anyone have info on/ or experience with this setup in DC2?
setup is
97 B20 Block
97 GSR Head
FS: 15" Mugen MR5 Black w/ Tires
text562507031.4
KeepItSimpleJDM is offline   Reply With Quote
Old 06-09-2010, 03:25 PM   #2
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
Send a message via AIM to EHondaJDM Send a message via Yahoo to EHondaJDM
Default Re: b20 vtec w/ GSR Head???
goes together just like any other b series
EHondaJDM is offline   Reply With Quote
Old 06-09-2010, 03:44 PM   #3
b18c1boostfreak
b18c1boostfreak's Avatar
its good it will run a friend of mine has a b20b with a gsr head pretty much fully bulit and he put out 230whp and 248 tq and it was real quick
gsr eg hatchback on j mags
b18c1boostfreak is offline   Reply With Quote
Old 06-09-2010, 03:51 PM   #4
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
10-4 its got a flat torque line thru the rpms
Old 06-09-2010, 04:29 PM   #5
racebum
2002 Chevrolet Corvette
racebum's Avatar
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
slightly faster than a stock itr even with the smaller gsr cams. these often have a short life though. one of my friends created one from a wrecked crv they had at his work. wound up running a 14.5@98mph
now on to the bad. the engine made it 3 oil changes before a rod broke
the b20 and b18b stock were never designed for 8,000+ rpm
Mountain View Carpet Cleaning also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 06-09-2010, 04:32 PM   #6
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
yea deff install a block guard!!! b20s have mean cylinder walk after 5k, also if you could get your hands on a 01 b20z2 or the jdm 01 b20b they are the best ones to get. the b20b has the highest compression for b20s
Old 06-09-2010, 06:11 PM   #7
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
I've had this setup before. But only took it to 7800rpm. Lasted awhile but got annoyed of the Frankenstein DD. Gotta love the torque though
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 06-09-2010, 06:43 PM   #8
racebum
racebum's Avatar
Racebum
hmm that's a thought if you redlined the engine at 7000 the b20 would probably live awhile and you would have a fairly quick car. even if you're down 10-15hp compared to 8000 engine life is drastically increased.
Old 06-10-2010, 10:45 AM   #9
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Yeah, it wasnt bad but again I like to rev high so had to switch back to a mild built gsr. I honestly should have built the b20 and go all out. LOL
www.Xenocron.com
Old 06-11-2010, 03:01 PM   #10
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
my buddy jus got this in today!
if your gonna do a b20 this is the one to get!!
anyone know if you could us this manifold??? i know it wont fit under the hood but will it run???? its a beast!
Old 06-12-2010, 05:53 AM   #11
ls2typer15
yea i had a b20 stock block and a gsr head with valvetrain in a dc2. the car ran `14.5 this is with dc5 17in type r rims and with full interior. love the TQ. if anything i have 3 wisco pistons with ls rods for the b20
ls2typer15 is offline   Reply With Quote
Old 06-12-2010, 06:13 AM   #12
ls2typer15
if u goin to use the b20 head u will have to use a ls mani
Old 06-12-2010, 08:01 AM   #13
94VTECoupe
94VTECoupe's Avatar
Send a message via AIM to 94VTECoupe
block guards are ugly creatures... Essentially you're fixing the top portion of the cylinder from expanding so the middle part of the cylinder actually flexes more and can cause damage... I'm not sure about the cylinder walk issue, but I can imagine it does because of the longer stroke.
On that note, because of the longer stroke, the rods swing side to side further than a short stroke engine... So at least get some beasty rod bolts if you're going to do it...
94VTECoupe is offline   Reply With Quote
Old 06-12-2010, 11:07 AM   #14
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
Um isn't the block guard to stop cylinder walk??
And y wouldn't u just use 2 one at the top and on in the middle?
Old 06-12-2010, 08:16 PM   #15
racebum
racebum's Avatar
Racebum
block guards help to prevent blown head gaskets from cylinder walk. they are what they are. as always if you want to make a high spinning motor or a lot of whp boosted you go sleeved or dart
Old 06-12-2010, 08:23 PM   #16
95skunkedgsr
95skunkedgsr's Avatar
Send a message via ICQ to 95skunkedgsr
buy rods and arp rod bolts for it and your set
95skunkedgsr is offline   Reply With Quote
Old 06-13-2010, 07:23 PM   #17
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
Wouldn't tach it too high tho
Old 06-13-2010, 07:28 PM   #18
GranDaddyPurp
GranDaddyPurp's Avatar
i have b20 vtec with gsr head dont need a block guard waste of time and money doesnt do anything if your sleeves are gonna crack a block guard wont help.
look into upgrading your rod and rod bolts. either shotpeen or get some forged.
im running stock just upgraded rod bolts and i take it up to 8k all day. now i dont leave it at 8 too long and i take care of my motor. if your stuff is built right and you checked and double checked your motor should be good.
have faith in your setup and know your limits you should be okay. b20 is good but if you can go lsvtec
GranDaddyPurp is offline   Reply With Quote
Old 06-14-2010, 04:07 PM   #19
EHondaJDM
1995 Acura Integra
EHondaJDM's Avatar
97, b20, b20b, block, gsr, head, motor, remove, setup, stock, top, tuned, vtec, wiht, worked
