| Welcome to Honda-Tech! | ||
#1 |
1993 Honda Del Sol |
1993 honda del sol S.
my car would crank and i couldnt hear my fuel pump cut on. i disconnected the relay and ran a jumper, fuel pump then cut on. so ive determined that its the relay. my question is how do u remove this relay. i ve been working at it for the past hour with now luck. anyone have a suggestion? |
#2 |
Technical Hero
OBD1/2 SOHC/DOHC VTEC SUBHARNESS MINI ME SUBHARNESS 02 EXTENSION HARNESS - www.hondapartshero.net |
#3 |
1992 Honda Civic |
it should be held on with 1x 6mm bolt, IIRC.
| Tags |
| 1993, del, diagram, dol, dx, fuel, fuse, hatch, hatchback, honda, location, pump, relay, removal, remove, sol, wiring |
