How much will a K Swap Cost?
Old 05-25-2010, 06:21 PM
  #26
burnykawizzle's Avatar
Default Re: How much will a K Swap Cost?
if you want REAL PRICES GO TO SWAPSHOPRACING . COM they have everything for a k swap
Old 05-26-2010, 12:12 AM
  #27
pm4nudes
chewyv's Avatar
someone selling a swap here for 2300 +/- a couple things. your looking around 3-5k. its not that pricy anymore.
Old 05-26-2010, 07:08 AM
  #28
ultraplayer26's Avatar
if your looking for hp k is not the way to go.if you want torque then k is for you..but for hp any other honda series engine will put out more power than k with just a bolt on ebay turbo..just keep doing what your thinking of more and more research..k20.org is probably where you need to be..goodluck..
Old 05-26-2010, 10:59 AM
  #29
raidacaipo's Avatar
another K vs other motors argument..
Old 05-26-2010, 12:33 PM
  #30
Tyte-S's Avatar
Originally Posted by boxeocampeon
yeah but how many k20s are at the junkyard tho
A shitload...Check out www.car-part.com It will search all the salvage yards for any part you want for any car...and list them starting with the closest to your or the best price...
Old 05-26-2010, 12:34 PM
  #31
Tyte-S's Avatar
if your looking for hp k is not the way to go.if you want torque then K24 is for you...
FIXED
Old 05-26-2010, 08:43 PM
  #32
look up g23 vtec and its half the price of k series
Old 05-26-2010, 10:56 PM
  #33
DSRxCandyh2bEG's Avatar
a swap header is anywhere from 800- 1200 bucks, k pro is 1000... Motor mounts are 500+. That's already around $2500... K series can get expensive but they have a lot of portential.
Old 05-26-2010, 11:05 PM
  #34
shak3yb0n3z's Avatar
I can source a K24A2 swap, engine, trans, ecu, wiring harness for 1900 out of a 2006 TSX. If you do it yourself you'll save a ton of money. take your time and pay as little as possible for the parts.
Old 05-27-2010, 01:32 PM
  #35
b16vt3c's Avatar
g23 is gnna cost you 3k.....my boy build one already.....& drop it into a ef9 hb......but just build your d16 for boost or all motor...boost is alot cheaper you can slap a t25 out of a volvo or saab out of the junkyard hf manifold run 6-8psi your good for a while......
Old 05-27-2010, 02:58 PM
  #36
dc2luver's Avatar
Call Hybrid Racing. Or check the website yourself hybrid-racing.com
Old 05-27-2010, 03:00 PM
  #37
prsferna0918's Avatar
its gona run u anywer from 5-8k depending on wether u do it urself or tak it to a shop...in ur case ur better off getting a b-series and putting som money into it n it will make ur target 215wph no problem and you won't have to spend anywhere near what it cost for a k swap
Old 05-27-2010, 07:53 PM
  #38
you can build a g23 vtec for about 2k thats already including the parts... and you will have the top and bottom end that you will want... just look up that build and youll see how people compare it to a k swap
Old 05-27-2010, 08:19 PM
  #39
bsmith100's Avatar
Originally Posted by Jdm Jerkz
I want something more revelant
When did the B series engines become irrelevant?
Old 05-27-2010, 08:25 PM
  #40
yang_shena's Avatar
If you are buying the swap it'll be around 2-3k.
Old 06-14-2010, 03:48 PM
  #41
Art8609's Avatar
I just finished my ek k swap and I spent over 8k!! It's really expensive if you do it right the first time.
Old 06-14-2010, 04:47 PM
  #42
Master Detailer
98civdx's Avatar
Shoping around is the best you can do, my friend's k swap was a tad over 10k, but its damn near brand new. Tsx block with 3k, and the rest from rsx with 5k on it.
Bought pretty much everything brand new. But he also bought a lot of things he didnt technicly need.
Old 06-14-2010, 04:56 PM
  #43
Corksil's Avatar
the simple answers are listed below. take your pick.
more than you expect.
it depends.
how deep are your pockets.
Old 07-01-2010, 08:54 AM
  #44
tommycharlton's Avatar
check this months issue of honda tuning magazine. they have an article about how to do a k swap for less
Old 07-15-2015, 02:23 AM
  #45
Zo300's Avatar
Originally Posted by fungus mungus
You can get a K-swap for $2000-5500 depending on if you look for them on craigslist or if you go to hmotors. The latter being the much safer route. Then you have to put it in. It's a lot more involved than a B-series swap...fab is required, gas tank has to be sourced, custom harness, etc, etc have to be acquired and installed..and that will cost a lot. I've seen figures as high as 8-10K to get a K-swap in an EG and running properly. Oh, and if you want 215whp, you'll have to throw money into it to get it there. Even the JDM Type-R K20A is 220whp at the crank, or about 187 whp.
In short, be prepared to spend a lot of money and time getting it right.
fm
There is no reason one would have to source a gas tank for a motor swap. Maybe a higher flowing pump, but even that's not mandatory.
Old 07-15-2015, 02:56 AM
  #46
Steve at Heart
Bently_Coop's Avatar
Wow, 5 year thread bump. Good thing your here to correct all the misinformation.
Old 07-15-2015, 08:09 AM
  #47
SpeedRacerEX-R's Avatar
Someone mentioned something about needing to put that in to pass Jerry Brown's smog test.
Old 07-15-2015, 08:45 AM
  #48
92HatchHybrid's Avatar
can ghetto it in. Doing it right and upgrading parts im near 8500.
Old 07-15-2015, 01:44 PM
  #49
fungus mungus's Avatar
Default How much will a K Swap Cost?
Seriously, you woke a dead thread to "correct"something I wrote 5 years ago? At the time of that posting, if you wanted to get the car BAR'd in California, this is what you had to have. I suspect this hasn't changed.
fm
Freemananana
17
05-29-2014 06:58 AM
96-wagon-boy
07-28-2012 05:40 PM
Neptronix
26
05-30-2007 07:06 PM
jfrase06
04-16-2007 01:37 PM
Quick Reply: How much will a K Swap Cost?
