96 Accord LX Codes P1361/P1362/P0335
Old 05-20-2010, 08:34 AM
partialresponse's Avatar
Default 96 Accord LX Codes P1361/P1362/P0335
I've been getting the codes P1361/P1362 every several months. These are related to the crankshaft position/TDC sensor behind the crankshaft pulley. I reset them with a code reader and all is fine for several months. Then either returns. There is no problem driving the car, but occasional difficulty starting the car. Yesterday P0335 appeared (also related to the crankshaft position sensor.) This was accompanied by poor acceleration. I reset the code and all has been fine so far. I have checked both connectors under the engine that carry these signals and they seem fine. Just for good measure I unplugged and plugged them back.
How likely is it that the sensors are actually bad? I don't mind replacing them since I have a timing belt replacement due and I'll have to get down there. But the sensors are rather expensive ($200) and I'm wondering if there's some other reason for the codes (other than sensor failure.) I see oil leaking out of the bottom of the lower timing belt cover and wonder if the oil has anything to do with the codes.
I don't see any posts here concerning sensor failure so I'm inclined to think it's not common. My car has 160k miles on the odometer.
-Kofi
Old 05-20-2010, 02:08 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: 96 Accord LX Codes P1361/P1362/P0335
The oil is probably the front main seal which you would want to do when the timing belt it done. You can "bypass" the sensor and see if it changes anything
http://www.ff-squad.com/technet/ckftrick.htm
Travis Gold
06-17-2018 01:08 PM
Aaron Tanner
10-29-2015 06:26 AM
wrlundberg
06-04-2014 12:14 PM
RWSStudios
Engine Management and Tuning
04-06-2014 12:08 PM
Mr Mike
12-16-2012 01:31 PM
Quick Reply: 96 Accord LX Codes P1361/P1362/P0335
