Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 05-19-2010, 04:21 PM   #1
GSR4door
1996 Acura Integra
My Garage
GSR4door's Avatar
Default Motor mounts and engine vibration Solved!
So..I recently installed Energy motor mount inserts on my B18C teg and ever since then, it's had a really bad harmonic engine vibration. The steering wheel would vibrate really bad at idle and you'd feel it through the gas pedal even at highway speed. It got so bad that my crank pulley came loose. Fortunately I was able to replace the pulley and there was no crank damage but I still had the vibration problem and it was driving me nuts! Google searched and found a thread that talks about a motor mount tightening sequence. I was skeptical but since the problem started when I was working on the mounts, I decided to give it a try. IT WORKED! Vibration is gone. Basically here's what the thread advised. You attach all mounts to the engine and trans and loosely tighten the bolts from the mount to the chassis. Then go back and tighten the mount to chassis bolts in this order.
1. right top trans mount
2. left top engine mount
3. rear trans mount
4. right front trans mount
5. left front engine mount
Has anyone ever heard this! I actually think this was the reason my front pully came off on my original engine and ruined the crank. Happened after a clutch replacement and I blamed it on a bad rebuilt flywheel.
GSR4door is offline   Reply With Quote
Old 05-19-2010, 09:29 PM   #2
90sedan
90sedan's Avatar
Send a message via AIM to 90sedan
Default Re: Motor mounts and engine vibration Solved!
I've never tried to follow an exact sequence, but it is a good idea to get all the motor mounts in before torquing them down.
Also when installing motor mounts either stock/aftermarket (non solid) its recommend to "neutralize" the mounts to help reduce vibration. Install the mounts without fully tightening them and power brake the car in both the forward and reverse direction. This will place the mount in a more "neutral" resting place. Finish by torquing to spec.
SpeedFactory Tuning and Race Fabrication
90 Ef Sedan
vitara d16
90sedan is offline   Reply With Quote
Old 05-20-2010, 08:51 AM   #3
Mikey3000
Mikey3000's Avatar
Send a message via AIM to Mikey3000
cool, good info!
92 Civic CX - Turbo H22A, 700+whp @ 29psi
10.42@144mph (148mph)
Good folks: Joe Simpson@Tempest Racing, Jeremy Allen@InlinePro
Mikey3000 is offline   Reply With Quote
Old 07-14-2010, 04:53 AM   #4
GSR4door
1996 Acura Integra
My Garage
GSR4door's Avatar
Just a follow up. After about 5000 miles, engine vibration is now completely gone. I think the Energy mount inserts take a while to get settled in. Tightening sequence made a huge difference right away, and I think time took care of the rest.
Old 04-02-2012, 08:33 AM   #5
Kalinkata
I have 98 Gsr with Jdm B18c type R swap. I recantly installed polyurethane bushings in mine and the vibration was so bad it gave me headache lol. So I did what u said and a lot of the vibration went away but there is still vibration when the car is on low rpm and when I turn on the a/c and the car is ideling. It drives me crazy. Do u have any idea how to fix it?
Thanks in advance.
Kalinkata is offline   Reply With Quote
Old 04-03-2012, 04:23 PM   #6
Perfectionist
When I replaced the mounts on my old 90 Civic Si, I recall the Helm's manual noted a specific sequence to torque engine mounts or vibration problems could result.
2003 PWP RSX-type S
"Need Help" or "Quick Question" = NO CLICK
"I may not always be right, BUT I'm never wrong."
Perfectionist is offline   Reply With Quote
Old 09-26-2013, 04:45 AM   #7
zkdawg
2004 Honda Civic
zkdawg's Avatar
NMZK81808
Post Re: Motor mounts and engine vibration Solved!
i just bought a 04 V.P. 1.7L and this thing has some BAD vibration and its relevant the the motor and rpm as it gets better with more rpm.
the old owner had the trans. replaced and it was bad after.
he goes back there and they said it was like that when they got it... shocker
so im going to try this torque sequence and report back
zkdawg is offline   Reply With Quote
Old 09-29-2013, 12:19 PM   #8
zkdawg
2004 Honda Civic
zkdawg's Avatar
NMZK81808
well i finally did it and the vib. is nearly gone.
acura, aftermarket, b18c, car, engine, honda, integra, motor, mount, mounts, nsx, odyssey, sequence, solid, torgue, vibration
