Old 05-19-2010, 06:43 AM   #1
heeltoehonda
heeltoehonda's Avatar
Default Clutch Pedal Squeaking
What would cause a clutch pedal to squeak when pushed in and let out?
94 Si
heeltoehonda is offline   Reply With Quote
Old 05-19-2010, 06:44 AM   #2
apexi_rsx
Send a message via AIM to apexi_rsx
Default Re: Clutch Pedal Squeaking
i dunno mine does it too lol i dont worry about it
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 05-19-2010, 07:24 AM   #3
ken9
ken9's Avatar
There's little spring clip under the pedal.. It might be that need some lubricating..It wouldn't affect driving much. Just annoying squeaking..
ken9 is offline   Reply With Quote
Old 05-19-2010, 07:33 AM   #4
heeltoehonda
Just a little wd40 do the job? Or should I use gear oil or something like that?
94 Si
Old 05-19-2010, 08:31 AM   #5
hondamark35
2000 Honda Civic
hondamark35's Avatar
use aerosol white lithium grease. it's good for springs and hinged joints because it goes on as a liquid then sets up thick to stay put and not drip off. i'm betting this is what the service manual recommends.
Currently on forum hiatus. build updates can be found here-> Build/Project Blog I can still be reached by PM.
hondamark35 is offline   Reply With Quote
Old 05-19-2010, 09:07 AM   #6
BryanM.
Resident Gearhead
BryanM.'s Avatar
iTrader Rating: (1)
Both my Civics have had this problem, in both cases it was the master cylinder itself that was squeaking as the piston went in an out.
BryanM. is offline   Reply With Quote
Old 05-19-2010, 09:33 AM   #7
forcefedeg01
1992 Honda Civic
forcefedeg01's Avatar
yep, white lithium grease fixed mine, now slave cyl makes noises cuz its dry where it meets the fork. i swear if its not one thing its the next..
forcefedeg01 is offline   Reply With Quote
Old 05-19-2010, 11:19 AM   #8
apexi_rsx
the sqweeking i noticed it was outside the car. it sounded to me the slave cylinder was sqweeking inside the fork as it pushed out
97 civic 4dr turbo
Old 05-20-2010, 05:56 AM   #9
heeltoehonda
Thanks
Originally Posted by mcvtec View Post
Both my Civics have had this problem, in both cases it was the master cylinder itself that was squeaking as the piston went in an out..
Hopefully it's just a joint, I guess I'll find out when I use the grease.
On your civic how did you fix it? Did you end up replacing the master cylinder?
That's the one thing I hate about older hondas, lol.
Did you ever get the slave sylinder noise fixed?
Mines deff comeing from around my clutch pedal.
Did you ever get it fixed?
94 Si
Old 05-20-2010, 12:11 PM   #10
forcefedeg01
1992 Honda Civic
Yea its quiet now, i used synthetic bearing grease (pennzoil) and put some in between the fork and the slave cyl mating surface. I had this happen before on my old turbo hatchy and it was quiet for more than 4yrs
Old 05-20-2010, 02:30 PM   #11
jesman1988
2006 Honda Civic
jesman1988's Avatar
Nice information my civic just started to do this.
jesman1988 is offline   Reply With Quote
Old 05-20-2010, 08:52 PM   #12
vsikwit
OMG mine has been doing it for so long i was going CRAZY, thank u its gone now
vsikwit is offline   Reply With Quote
Old 05-21-2010, 04:57 AM   #13
heeltoehonda
Thanks for all the imput guys.
94 Si
04, 06, 2002, 2005, accord, civic, clutch, honda, lubricant, pedal, rsx, squeak, squeaking, squeaks, squeaky, sqweek
