Old 05-16-2010, 10:53 AM   #1
SlammedDC2teg
SlammedDC2teg's Avatar
Default 96 Accord, leaking coolant from backside of engine.
I have a 96 Accord that is leaking like crazy from the backside of the motor, right by the water pump where the pipe that connects to the thermostat.
Has any one had a similar problem? I don't want to spend to much time, nor money fixing this car. It was hand me down with over 200k. I can do the work my self, but I just wanted to see if any one has had the exact problem, and what is it?
Also does any one have a PDF of repair manual for a 96 Accord.
Thanks in advance HT.
05 Acura TSX NHB CL9 Squad Member #90
04 Honda S2000 SSM
DC Squad Member # 0382
SlammedDC2teg is offline   Reply With Quote
Old 05-16-2010, 11:40 AM   #2
cctgene
1991 Honda Accord
cctgene's Avatar
Default Re: 96 Accord, leaking coolant from backside of engine.
http://hondatech.info/downloads/Auto/Manuals/Accord/
cctgene is offline   Reply With Quote
Old 05-16-2010, 01:50 PM   #3
sony224422
sony224422's Avatar
there are o rings. I had the same problem.. if the pipe isn't lined up right then you nick the o ring and it leaks eventually. I also had mine rust out and it had a pin hole leak. Bought a new one, 2 new o rings, and was good as new. Its not too hard to do either, just make sure you take the bolt out of the bracket that holds it, and lube the o rings before shoving them in.
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline   Reply With Quote
Old 05-16-2010, 03:40 PM   #4
SlammedDC2teg
^+1 Right on man. I'm going to pick some o-rings up and do the job. Thanks
04 Honda S2000 SSM
Old 05-16-2010, 06:11 PM   #5
quickster
the thermostat housing can be a b$tch to get out, but yea....definatly that O-ring. Its an easy fix. Shouldn't take more than about 45mins to do yourself. Drain your coolant out from the plug on the bottom of the radiator before you do it or you will have a mess on your hands. Might as well change your thermostat while you are there too since I think you gotta take out the thermo housing anyway to get that pipe off. and maybe the radiator hose that connects to the housing if its looking old.
I own a 1991 Honda Accord LX 2.2 145k miles
quickster is offline   Reply With Quote
Old 05-16-2010, 08:59 PM   #6
SlammedDC2teg
What would I use to lube them?
04 Honda S2000 SSM
Old 05-16-2010, 11:02 PM   #7
RICKSAUTOMOTIVE
1990 Acura Integra
RICKSAUTOMOTIVE's Avatar
WD-40...tri-flow....something like that. i spray my finger and lube the O-rings by wiping them. just put enough to help you get it together
RICKSAUTOMOTIVE is offline   Reply With Quote
Old 05-17-2010, 12:34 PM   #8
sony224422
sony224422's Avatar
yep anything is better than dry lol.. spit if you have to.
360 magnum
Old 05-17-2010, 12:35 PM   #9
sony224422
sony224422's Avatar
when i did mine, you don't have to take the thermo out.. i took off the whole assembly as one. I think there is a gasket behind there too actually just so you know.
360 magnum
Old 05-17-2010, 02:18 PM   #10
SlammedDC2teg
Thanks for all the help fellas. I just finished. The back bolt that holds the pipe was a PITA to take out and put back. It probably would have taken me 20min to do the job rather than 2hrs, due to the bolt. Other than that is was a $6 fix. Thanks again for your help.
04 Honda S2000 SSM
Old 05-17-2010, 03:33 PM   #11
sony224422
sony224422's Avatar
no problem.. atleast you knew about the bolt lol.. first time i did it i had no idea and i couldn't figure it out until i saw it. i found a 12 mm gear wrench to be my best friend after that.
360 magnum
Old 05-17-2010, 03:51 PM   #12
SlammedDC2teg
That's exactly what I wished I had.
04 Honda S2000 SSM
90, 91, accord, backside, bottom, coolant, engine, honda, hose, leaking, pin, pipe, radiator, tech, thermostat
