Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord & Crosstour (2003 - Current)
Old 05-09-2010, 11:42 AM   #1
nabeel24
Default Driver side A/C
Hey guys, had a question about a problem on my 2003 Accord, btw its a EX V6.
So I had my Tranny rebuilt a few days ago and before the tranny rebuilt my A/C was working perfectly. Now after the rebuild in which they disconnected the battery, the driver side does not blow cold air. The passenger side works perfectly, it blows hot and cold air, the driver side on the other hand blows hot air if I set to it but not cold air. The air it blows when I turn it to cold feels more or so just like the fan is on or outside air. It is a dual A/C system. If anyone can help out with this, would be great. Thank you!
nabeel24 is offline   Reply With Quote
Old 05-10-2010, 04:35 PM   #2
nabeel24
Default Re: Driver side A/C
Anyone experience any problem like this, that can help out?
Old 05-26-2010, 05:44 AM   #3
rhino1
nab, i signed on here to get similar info. except, i am the shop owner who changed the color, paint job, on an 06 accord. the battery died on us and after everything was said and done, we get nothing blowing out of either vents. no heat, no a/c, no defrost, nothing. i know for a fact that we did not touch anything having to do with the a/c. but now it does not work.
rhino1 is offline   Reply With Quote
Old 05-29-2010, 07:22 PM   #4
KWayRacing
KWayRacing's Avatar
NAb, your vehicle is most likely slightly low in charge. Theres no reason to discahrge the ac during transmission removal on your vehicle. Might just be a coincidence. Have the shop check it out? If they can't or will not take it to someone who can. WIth such a large ticket. 2500$ plus, unless they are die hard I didn't do it(because they didn't) they shouldn't have any issue with checking it out, then selling you the actual repair.
Rhino, does the ac compressor and underhood cooling fans kick on but no air comes out of the vents inside or no ac function at all. THis maybe a coincidence also, the transistors are prone to failing in this model accord.
KWayRacing is offline   Reply With Quote
Old 05-30-2010, 10:03 PM   #5
nabeel24
Yea turns out it was low on charge. But for no reason I was driving the car yesterday and the ac compressor didn't turn on, but after starting back up after stopping somewhere it worked. It hasn't happened again but was weird.
Old 05-31-2010, 06:46 PM   #6
KWayRacing
KWayRacing's Avatar
Have replaced a few compressor coils dor that reason, Also have found a few faulty relays for the same reason. If it doesn't happen again I wouldn't worry about it.
Old 06-01-2010, 09:49 PM   #7
tumpa33
2003 Honda Accord
I have a simular problem some times my ac compressor stop working after cycling 4 or so times stop working 2 minutes later comes right back on can someone tell me what is happening.
tumpa33 is offline   Reply With Quote
Old 06-24-2011, 10:05 PM   #8
Vic2003
Also have 2003 Honda Accord 4 cyl. A/C starts and stops, very annoying. Cabin filter and a/c blower have been replaced. Anyone have idea on what it may be?
Vic2003 is offline   Reply With Quote
03, ac, accord, air, cold, cool, driver, drivers, honda, hot, odyesse, odyssey, oydessey, passenger, side
