92-95 hatch lift support removal
Old 05-04-2010, 01:47 PM
H-T White Ops
NOFX's Avatar
Default 92-95 hatch lift support removal
Having some trouble getting these things off. They seem stuck. The entire piece through the glass just spins.
Any tips or links?
Old 05-04-2010, 01:48 PM
H-T White Ops
NOFX's Avatar
Default Re: 92-95 hatch lift support removal
The outer cap didn't look like enough to grab with vice grips or anything, plus we don't want to damage them.
Old 05-04-2010, 10:09 PM
H-T White Ops
NOFX's Avatar
Okay. He managed to get the one side off the glass, but the other side seems stuck.
The upper piece mounted to the c pillar won't come off.
Old 05-05-2010, 11:52 AM
red Teggie's Avatar
So, you're saying you can't loosen it with the wrench?
The bolt is welded on to the body, so you should be able to use the wrench to take it off.. Unless it's seized..
I recently replaced the hatch shoch and didn't have a problem..
Old 05-05-2010, 12:27 PM
Oh look, I can change this
deschlong's Avatar
No, don't grab the outer cap with vice grips or the like. You'll definitely damage it. It's made of a soft metal (aluminium?) Also, when you ARE removing the hatch support at the glass, it is VERY easy to cross-thread and ruin the threading. The best way to prevent this is to make sure the strut is fully extended (hatch glass all the way up) and then manually support the glass, removing the weight from the strut. You need a 12cm box-end spanner wrench to remove the nut ... as for the problem of it spinning in place ... I really don't know, as I never experienced that problem. Anyway, hopefully some of the other info helped.
Old 05-05-2010, 01:30 PM
H-T White Ops
NOFX's Avatar
Figured out why it was so difficult. The driver side was glued on and the passenger side was stripped.
Got it off now though. Have to replace all the pieces on the glass anyway since they were already damaged beyond repair.
Thanks for the help.
ShinyNewPenny
16
04-13-2009 08:10 PM
'90crxSI
05-31-2006 08:38 PM
All Motor EH2
03-21-2005 04:40 PM
LankorDie
13
07-10-2004 08:30 PM
chhuong
08-18-2003 10:52 AM
Quick Reply: 92-95 hatch lift support removal
