Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 04-29-2010, 04:23 PM   #1
schueytenten
schueytenten's Avatar
Default $800 AC Compressor replacement??
Just took my 91 Si in because it was not cooling too well. Thought it was just low on freon. The shop tells me the compressor is leaking and needs to be replaced. $800 damn dollars. Jeezus. He said it was a $350 part and the rest was labor and freon.
My tech question is how hard is it to replace it myself and just get it recharged from him? I see majestic has the part for $320 (I have found cheaper on the internet too). How difficult is it to replace the compressor myself? Looking through the helms it doesn't seem like its too difficult, but I wanted to ask before I flock it up to save a couple hundred bucks.
Is the part from majestic going to be new, or reman also?
thanks
schueytenten is offline   Reply With Quote
Old 04-29-2010, 04:27 PM   #2
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
iTrader Rating: (1)
Default Re: $800 AC Compressor replacement??
not very hard at all since all that you have to remove are 4 bolts,2 ac hoses and the ac belt...you can probably find a used one for cheap on the marketplace or craigslist or just buy a new aftermarket one from vatozone...!!!
BiG ChOr!Zo'S Garage Sale Thread v.2<--click me
BiG ChOr!Zo is offline   Reply With Quote
Old 04-29-2010, 04:45 PM   #3
shawn_crx
shawn_crx's Avatar
pretty easy,
shawn_crx is offline   Reply With Quote
Old 04-29-2010, 06:05 PM   #4
sirtef9
sirtef9's Avatar
iTrader Rating: (4)
http://www.facebook.com/vtedpowa
thanks
That's a good ol' rape job even without lube, Do it yourself man!
1992 Gs-R #1143, 7/12/13, 375whp 14lbs, stock b17, e-85
1999 Subaru Legacy Outback, daily driver
1991 Honda Civic Si, under construction
sirtef9 is offline   Reply With Quote
Old 04-29-2010, 06:10 PM   #5
roadsqueegy95
1999 Honda Civic
roadsqueegy95's Avatar
easy!! id say take it to another shop first, and have them look at it and if it realy is the compressor replace yourself
Get your honda-tech.com decals....on sale now!!
http://www.honda-tech.com/showthread.php?t=2573880
www.AbsoluteCustomsLLC.com
roadsqueegy95 is offline   Reply With Quote
Old 04-29-2010, 06:31 PM   #6
B16-CRX
B16-CRX's Avatar
Send a message via AIM to B16-CRX
Yea, do it yourself. Should not cost nearly that much. I bought a whole A/c system for 300 and installed it in my car without a hitch.
B16-CRX is offline   Reply With Quote
Old 04-29-2010, 07:18 PM   #7
zsoccerdude17
Make sure you recover your old refrigerant first.
zsoccerdude17 is offline   Reply With Quote
Old 04-29-2010, 07:51 PM   #8
Echo 6
Echo 6's Avatar
Yea definitely don't pay $800 just to have them change a compressor, you can get them re manufactured for less than $200 on eBay, although those have a shorter warranty. Just make sure you get the proper model (i.e. Matsushita or Sanden) to replace yours. Oh and you may need to convert your car to r134 if its not already
91 CRX Si - B18b, Blox intake manifold, B16b throttle body & injectors, Unorthodox pulleys, AEM intake, Innovative mounts & Competition Bar, etc...
Echo 6 is offline   Reply With Quote
Old 04-29-2010, 08:20 PM   #9
michael O
michael O's Avatar
Send a message via AIM to michael O
They told me $1200 cuz there wasn't enough room on my car....I told them I'd do it myself.
88 Crx Dx
B16A-->B18a-->B16A-->B18a
michael O is offline   Reply With Quote
Old 04-29-2010, 08:26 PM   #10
BiG ChOr!Zo
iTrader Rating: (1)
they probably wanted to remove the motor just to take off the 4 bolts the lazy way...!!!
Old 04-29-2010, 09:28 PM   #11
KINGVEM^^ED6
1991 Honda Civic
My Garage
KINGVEM^^ED6's Avatar
iTrader Rating: (1)
Serious do it your self bro
Originally Posted by tonylovesjdmEF9 View Post
i would choke my ex it was pretty fun and wild
KINGVEM^^ED6 is offline   Reply With Quote
Old 04-29-2010, 09:46 PM   #12
wolfsbain
1990 Honda CRX
My Garage
wolfsbain's Avatar
its pretty easy to do. just take your time
wolfsbain is offline   Reply With Quote
Old 04-30-2010, 06:27 AM   #13
Jaime 91SiB18
Jaime 91SiB18's Avatar
I paid $130 on Ebay for a BNIB compressor.
You'll need to pull a vaccum before charging the system with new refrigerant.
Also replace the dryer.
Jaime 91SiB18 is offline   Reply With Quote
Old 04-30-2010, 01:33 PM   #14
MrToxygen
Good advice Jaime
Ya bro i second this, not sure if your aware of service on ac but def pull vaccum, this will tell you if you have leaks before you go and fill the system with freon as well as prep it for freon. Then fill it up and your gunna be chillin!! replace all orings too take your time putting things together.. good luck!
MrToxygen is offline   Reply With Quote
Old 04-30-2010, 02:19 PM   #15
lunalink
lunalink's Avatar
lol. c'mon now. even you know you can get them alot cheaper at the yard.
I took my old A/C off in about 20min.
* but if you're scared to mess with it then.......idk.
lunalink is offline   Reply With Quote
Old 05-19-2010, 11:38 PM   #16
schueytenten
Bringing back my old thread. Getting ready to tackle the job. One question maybe someone will know while I am bored at this hour or I could just call the shop I took it to and ask them in the morning. I really want to get going right at sun up though.
Since my compressor has a crack in it and I was told all the coolant leaks right out, do I still need to take it back to him (or rent the machine from autozone) before I start and have it evacuated? I feel like I need to still get it all out. Which is correct?
Thanks
Old 05-20-2010, 01:12 AM   #17
DCRB
DCRB's Avatar
Send a message via AIM to DCRB
if there is zero coolant in the system then just take it apart. LEGALLY i am required to tell you it is illegal to vent that stuff to the ozone... lol but seriously if you're concerned about it take off one of the caps from one of the fill valves, and press the schrader valve in for a sec. if a whole bunch of freon comes spraying out have it evacuated. if nothing just tear it apart.
Build Thread - My 88 ED6 Daily - 97 Vr6 Passat Wagon
Originally Posted by BETOSCOUPE View Post
Plus my boss gets mad at me because she can't hear me 1/2 the time while I am on the phone with her lol "WHAT IS ALL THAT NOISE" - Bitch..... Its my Type R foo lol
DCRB is offline   Reply With Quote
Old 05-20-2010, 01:28 AM   #18
schueytenten
Thanks for the reply. That is what i had figured.
Old 05-20-2010, 09:53 AM   #19
zsoccerdude17
A/C systems use refrigerant not coolant.
Old 05-20-2010, 06:42 PM   #20
schueytenten
I thought the names might have been interchangeable with AC. I just used coolant because a FAQ I was reading mentioned to drain the AC system of all the coolant. Obviously I would put in freon, and not coolant.
Old 05-20-2010, 09:05 PM   #21
zsoccerdude17
Lol i figured you knew but ya never know.
Old 05-21-2010, 11:16 AM   #22
jdm_dc_fan
jdm_dc_fan's Avatar
Location: "That one guy with that one car" Kennewick WA
iTrader Rating: (1)
Im in a similar situation. Are all d series compressors interchangable?
And are there any other reasons the a/c wont work? My a/c button doesnt light up, will that cause any failures?
Jspec MR Integra R (sold)
BB S2000 (rolled)
NSX (in search of)
jdm_dc_fan is offline   Reply With Quote
Old 05-21-2010, 08:25 PM   #23
schueytenten
I had the same problem, it ended up being just a fuse.
Old 05-21-2010, 08:33 PM   #24
masterEF
1986 Mazda RX-7
masterEF's Avatar
theres a thread somewhere in the eg section that gives a step by step instruction on how to refill the ac
masterEF is offline   Reply With Quote
Old 05-21-2010, 08:43 PM   #25
natedawg500
natedawg500's Avatar
Send a message via AIM to natedawg500
I would look into buying a compressor on ebay. I paid 200$ for a sandan compressor. then pull a vacuum.
Last don't convert it to R134 you will be very disappointed. Its not cold at all in a CRX. The system is already fairly weak. I'd have to drive for an hour at highway speeds @ 4k rpm with the system on full blast to get remotely cool. (when I was on R134)
94 Supra 6spd white - 62mm turbo - 670whp @ 30psi on E85 - SOLD
99 Miata - Track car
natedawg500 is offline   Reply With Quote
2003, ac, accord, change, civic, compressor, condenser, cost, hard, honda, labor, mdx, putting, replace, replacement
