Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 04-23-2010, 01:56 PM   #1
wEaK Squad *ATL*
wEaK Squad *ATL*'s Avatar
Send a message via AIM to wEaK Squad *ATL*
Default Coilover spring replacement
I'm in the market to purchase some higher spring rate springs for my new apexi esv coilovers. Im familiar with different spring rates but I see that swift/stance offer springs in different lengths like 150mm, 175mm, and 200mm. What is the difference between these or is it determined by the length of travel needed?
Originally Posted by slywfbpsi View Post
Yeah I think I'm gonna let a bill go next pay period to get this
hahaha are you serious?????? wow... H-T is now 99% dumbass kids
wEaK Squad *ATL* is offline   Reply With Quote
Old 04-23-2010, 02:50 PM   #2
TunerN00b
TunerN00b's Avatar
Default Re: Coilover spring replacement
Yes, length of total travel before coil bind needed will determine which length you need.
If you want the car lower than the lowest spring perch setting, you need shorter springs. If you want to keep some preload, you'll need to figure out the longest spring that will fit.
If you're happy with the current height and adjustment range available, just buy replacement springs in the same length you currently have. You'll still need to lower the perch slightly to keep the same ride height with stiffer rates though.
TunerN00b is offline   Reply With Quote
Old 04-23-2010, 07:17 PM   #3
wEaK Squad *ATL*
Will shorter springs mean a sacrifice in ride quality? What other companies make custom rate springs for coilovers?
Old 04-25-2010, 11:26 AM   #4
STOCK_SOHC_DX
1990 Mazda Miata
My Garage
STOCK_SOHC_DX's Avatar
If you go too short, then you will be pretty much riding on your bump stops or bottoming out your shock shaft. Yes most quality spring companies make different spring rates for coilovers it just depends on your inner diameter of the spring. If your planning on changing your rate I would try to contact Apexi to see what those shocks can handle before you end up blowing your shocks.
STOCK_SOHC_DX is offline   Reply With Quote
Old 04-25-2010, 07:32 PM   #5
ejprimo
ejprimo's Avatar
Send a message via AIM to ejprimo Send a message via Yahoo to ejprimo
hypercoil, eibach ers, and swift all make custom springs for coilovers. just determine the inner diameter, length of spring, and spring rate you want. search the RR/AX forum for hypercoil or hyperco for some good input on these particular springs.
hypercoil: http://www.hypercoils.com/
eibach: http://performance-suspension.eibach.com/
swift: http://www.swiftsprings.com/
JRZ Novak Racing
ejprimo is offline   Reply With Quote
919, coilover, coilovers, custom, del, honda, hyperco, leght, replacement, short, shorter, sol, spring, springs, swift
