Old 04-14-2010, 07:14 PM   #1
wicked_gk
wicked_gk's Avatar
Send a message via AIM to wicked_gk
Default locked keys inside, help!
my car alarm automatically locks the doors when the key is on the on position and i got out and closed the door on accident. i was working under the hood and now i cant open the doors for ****. The hood is still up dunno if that makes it easier to open. i have power doors/windows, how can i open? please help!
garage:
97 Civic EK - 5spd *build in progress
93 Integra DA - 5spd *sold
wicked_gk is offline   Reply With Quote
Old 04-14-2010, 07:15 PM   #2
Papa_Dios
Default Re: locked keys inside, help!
sounds like you need a locksmith
Papa_Dios is offline   Reply With Quote
Old 04-14-2010, 07:19 PM   #3
redpreludesi
redpreludesi's Avatar
Send a message via ICQ to redpreludesi Send a message via AIM to redpreludesi
get your vin number and go to your local dealer and get a key made cheaper than a lock smith
redpreludesi is offline   Reply With Quote
Old 04-14-2010, 07:38 PM   #4
cbaber
cbaber's Avatar
OR, get a wire hanger and squeeze it through the top of the door through the seals. Make a hook or L shape at the end that you squeeze through. Now try to hook your lock button with that end. It takes time and a lot of effort to get it. You can try to open the lock or pull the door handle.
It does work though, I have done it at least 5 times with my Del Sol lol.
1998 Honda Civic HX - VX trans, P/S delete, ScanGauge II - 50 MPG
cbaber is offline   Reply With Quote
Old 04-14-2010, 08:55 PM   #5
95-db6-719
95-db6-719's Avatar
amen, i used a tig welding rod, and yes this works..
PASSWORD JDM/ JEGS/SPEED IMAGE PERFORMANCE/MISHIMOTO
DB8(the cleaniest bay out there)Build thread
http://honda-tech.com/showthread.php?t=2755334 The daily project: http://honda-tech.com/showthread.php?t=2976568
95-db6-719 is offline   Reply With Quote
Old 04-14-2010, 08:59 PM   #6
__oversea
__oversea's Avatar
sadly its easy.
i'd say it was wrong design.lol
__oversea is offline   Reply With Quote
Old 04-14-2010, 09:42 PM   #7
seanbev24
seanbev24's Avatar
It was disturbing how easy it was to get into my car when I locked myself out.
seanbev24 is offline   Reply With Quote
Old 04-14-2010, 09:46 PM   #8
90_EX_Civic
1991 Honda Civic
My Garage
90_EX_Civic's Avatar
use another honda key.
90_EX_Civic is offline   Reply With Quote
Old 04-14-2010, 09:58 PM   #9
RICKSAUTOMOTIVE
1990 Acura Integra
RICKSAUTOMOTIVE's Avatar
man i hated doing this at the dealer LOL. i would pull into my bay and get out while being careful not to hit the lift with the door, and i would shut the door and realize the doors locked!! LOL so there i am giving the car back with an extra key LOL. now 10 years later i have a habit of rolling down the window before i get out of a car to work on it LOL
RICKSAUTOMOTIVE is offline   Reply With Quote
Old 04-14-2010, 10:33 PM   #10
seanbev24
seanbev24's Avatar
The first thing I do when getting into a customer's car is roll the window down.
Old 04-14-2010, 10:37 PM   #11
WDG_729_ITR
WDG_729_ITR's Avatar
Just make sure that you disconnect you battery before you do this, if your alarm is activated...lol
"Life has become the ideology of its own absence." -Theodor W. Adorno
WDG_729_ITR is offline   Reply With Quote
Old 04-14-2010, 11:30 PM   #12
madblkscientist
madblkscientist's Avatar
clothes hanger FTW
BACKYARD MECHANIC
madblkscientist is offline   Reply With Quote
Old 04-15-2010, 05:02 AM   #13
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
I don't get it - how can you get out of your car and have the door locked when you close it? You have to unlock the door to get out. Are you locking it again before you shut it?
My alarm also locks my doors 3 seconds after starting the car, and unlocks them when I shut the car off. I ALWAYS drive with the doors locked, so it's very convenient for me. But my alarm is also smart enough to know when one door is open when the car is started, it won't lock the doors. If I have to get out while the engine is running, I unlock the door, and then lock it again when I get back in. It certainly does not lock itself after I unlock it.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 04-15-2010, 06:06 AM   #14
cbaber
cbaber's Avatar
On my 96 GSR if you have the key in the ignition and unlock the door from the inside while the door is open, it automatically locks both doors after a second. I assume his situation was similar.
Old 04-15-2010, 06:09 AM   #15
GagnarTheUnruly
1998 Acura Integra
My Garage
GagnarTheUnruly's Avatar
iTrader Rating: (3)
It is disturbingly easy to unlock the door from the outside.
GagnarTheUnruly is offline   Reply With Quote
Old 04-15-2010, 06:13 AM   #16
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
wow what a retarded design.
On my 94, if I hold the door plunger closed on the door jamb so that the car thinks the door is closed, then start my car and the alarm tries to lock the doors (door still open) it will try to lock but then immediately unlock.
member #0001
Old 04-15-2010, 06:21 AM   #17
92teginsc
92teginsc's Avatar
Send a message via AIM to 92teginsc
i always keep a spare in my wallet for times like these. op should do the same after this.
92teginsc is offline   Reply With Quote
Old 04-15-2010, 07:31 AM   #18
9600baud
9600baud's Avatar
youtube is your friend
9600baud is offline   Reply With Quote
Old 04-15-2010, 08:42 AM   #19
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
EXACTLY! I've kept a spare car key in my wallet since I got my first car in 1996. Parents suggested I do so, and I listened.
Only time it was a fail was when I was a freshman in college, living in the dorms. One Saturday morning I went out to piddle around with the car, ended up locking my keys in my car, with wallet locked in my dorm room. Luckily I lived on the ground floor and could open the window from outside and just barely squeeze through.
member #0001
Old 04-15-2010, 12:14 PM   #20
madblkscientist
not all alarms work like that for instance when i turn o the igntion it will lock the doors after i start driven, but if i turn the ignition engine off but kep acc on it wil lock the doors after sometime even if the key is in the igniton, bt if i turn the car off completeit will lock the doors after 5 secs when bot doors are closed so the best way is to kee a spare keep cause these arlarms are designed to lock ppl out including u
BACKYARD MECHANIC
Old 04-15-2010, 01:10 PM   #21
wicked_gk
wicked_gk's Avatar
tried for two hours straight with a slim jim... might have to call a lock smith
garage:
Old 04-15-2010, 01:52 PM   #22
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Haha I think we've all locked ourselves out of our cars before. So when it happened to me luckily I was in my garage but the dumb thing was I didnt have a spare key. I know stupid me. So I had to use a hanger, slid it through my window and pushed down on the unlock switch. Luckily there was no damage.
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 04-15-2010, 02:56 PM   #23
Blahblah718293
Blahblah718293's Avatar
Send a message via AIM to Blahblah718293
which is the reason i will NEVER drive a later model gm, or most fords, if i want the doors locked then ill lock them myself. i always roll down the window of any car im working on.
ive also kept a spare key to my car in my wallet for the past few years.
Just open your mind and knowledge will just pour right in
88 CBR600F-summer toy
81 CB900C- RUN DAMNIT!!!
Blahblah718293 is offline   Reply With Quote
Old 04-15-2010, 03:31 PM   #24
DumaDA
1990 Acura Integra
DumaDA's Avatar
the worst was in my lexus, i locked the key in the trunk with no spare and the doors locked, locksmith came and opened the door, which set the alarm off, causing all levels to automatically lock so i couldnt get to the trunk, had to have ANOTHER person come to remove the door panel and trip the door in order to unlock the trunk lol
RNR Built
Wanna-Be VIP
DumaDA is offline   Reply With Quote
Old 04-15-2010, 03:31 PM   #25
boarding2008
boarding2008's Avatar
HaryPooprScoopr
If its a sedan its super simple to get a hanger in there. Never had to do it to my sedan. Good luck op
92 Accord Sedan LX [sold for] -> 95 Integra DC4 [sold for] -> 95 Integra DB8 [sold for] -> 89 S13 Fastback[sold for] -> 94 BMW 325is[sold for] -> 99 CRV
92 Civic hatch - boosted d16z6 - 280whp 230trq @18psi
boarding2008 is offline   Reply With Quote
95, acura, door, hanger, hondai, hood, inside, integra, keys, lexus, lock, locked, open, rsx, unlock
