Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 04-12-2010, 09:20 AM   #1
GoLowDrew
GoLowDrew's Avatar
Icon6 Tool Talk - Impact wrench
What is the difference between impact wrench and a cordless electric drill?
Can I use my electric drill to install a coilover, for example?
TIA
New question at bottom Post # 15. http://honda-tech.com/showpost.php?p=46974215&postcount=15
GoLowDrew is offline   Reply With Quote
Old 04-12-2010, 09:23 AM   #2
Uncle Ben's
I rattle people's cages
2003 Honda Accord
Uncle Ben's's Avatar
Default Re: Tool Talk - Impact wrench vs Drill
I doubt it. Doesn't an impact wrench have a 3/8 or 1/2 inch cube on the end for sockets only, like a regular socket wrench? A cordless drill only has a little triangular thing that can accept cylindrical drill bits....
Originally Posted by Kiwibird83 View Post
I have been wondering how to fit all my spare boyfriends into one drop top sportscar.....
Uncle Ben's is offline   Reply With Quote
Old 04-12-2010, 09:29 AM   #3
GoLowDrew
GoLowDrew's Avatar
I figure they would sell an adapter for a drill that would allow one to use sockets. I've not look for it (yet).
Does anyone know? I'll make this a question too.
Old 04-12-2010, 09:32 AM   #4
Xentropa
The Science Guy
Xentropa's Avatar
Not quite the same. An Impact wrench has an internal hammer mechanism involving a weighted mass, pistons and some clutches, while an electric drill feeds a constant torque from a motor.
An impact wrench constantly "hammers" at a nut or bolt until it's loose. A hammer mechanism allows much higher torques than an electric motor's T = I x lB
_|ŻŻ|O
_|ŻŻ| . .. . .. O
This is where being stupid helps.
Xentropa is online now   Reply With Quote
Old 04-12-2010, 09:32 AM   #5
Backk InTheDA
Tiesto's Club Life
Backk InTheDA's Avatar
Send a message via AIM to Backk InTheDA
It might have an adapter, maybe? But I doubt it would have enough torque to break the bolt loose.
(see what I did there for all you retards who don't know the difference between lose and loose)
Originally Posted by 2LEM1 View Post
It was actually a challenge to get laid when I was a teenager, it sounds like now you just put your name on a list and chicks email you to ****. God dammit, back in my day we had to walk to a bar to meet chicks. And it was uphill. In the snow. BOTH WAYS.
Backk InTheDA is offline   Reply With Quote
Old 04-12-2010, 09:39 AM   #6
plamauski
plamauski's Avatar
Not sure why you would need either to install a coilover...
plamauski is offline   Reply With Quote
Old 04-12-2010, 09:50 AM   #7
GoLowDrew
GoLowDrew's Avatar
Someone suggested on another forum that unless "I'm 250lbs and works out regularly" I should use an impact wrench. Breaker bar will not cut it for an old girly man like me.
Work on a (2008-) 2010 Accord.
Old 04-12-2010, 09:57 AM   #8
shamoo
Will you make something up for me please?
2008 BMW M3
shamoo's Avatar
You won't need an impact wrench/ratched/gun for a coilover install. It might make some things quicker, but it definitely isn't a necessity. Like Xentropa said, it's the hammer mechanism that breaks the bolts loose. A constant torque like that from a drill won't do much to tighten/loosen stubborn bolts.
A nice ratchet set with some crescent wrenches are all you need.
'12 Fit Sport w/navi | '08 E92 M3 (Sold) | '07 S2000 (Sold) | '01 S2000 (Stolen) | '97 Integra LS (Sold)
'12 Monster 796 ABS | '05 YZF-R6 (Sold)
shamoo is offline   Reply With Quote
Old 04-12-2010, 10:34 AM   #9
Ghetto Civic HX
I love to drive
Ghetto Civic HX's Avatar
I don't work out at all and I was able to break loose all of the suspension bolts with with a 15" breaker bar.
I did use an impact wrench for the spring compressor though. It's easier to pull a trigger than use a ratchet. But I had to reuse the OEM top hats. If you're installing full coilovers then it won't matter.
Also, I'm in CA and there is just about zero rust under my car. Maybe those other guys have cars where the bolts are starting to rust to the suspension arms?
Ghetto Civic HX is offline   Reply With Quote
Old 04-12-2010, 10:38 AM   #10
sh!ft
Who the fack changed my title?!
1996 Acura Integra
sh!ft's Avatar
zack dennis Mr.Rabbit420
Send a message via AIM to sh!ft Send a message via Yahoo to sh!ft
the onlything a drill will do is spin YOUR wrist around and thus hurting/breaking your hand(S)
sh!ft is offline   Reply With Quote
Old 04-12-2010, 11:14 AM   #11
JDMHN8
Titty Sprinkles
JDMHN8's Avatar
Yep. Made that mistake 10 years ago. Never gonna do it again.
JDMHN8 is offline   Reply With Quote
Old 04-12-2010, 11:16 AM   #12
GoLowDrew
GoLowDrew's Avatar
I can imagine that. Thank you.
Old 04-12-2010, 12:09 PM   #13
96hb
96hb's Avatar
A drill will not have the same torque as an impact gun. And like was said, you really don't need one. I have replaced everything from shocks, springs, control arms, timing belt, water pump, exhaust, etc...using nothing more than basic hand tools. Unless you live up north around salt and snow, your bolts should not seize up on you. I would suggest using some PB Blaster on them but that's about it.
96hb is offline   Reply With Quote
Old 04-12-2010, 12:18 PM   #14
Mikey3000
Mikey3000's Avatar
Send a message via AIM to Mikey3000
yes but buying a snap-on 18V cordless 1/2" drive impact gun for $500+ will be your best friend forever.
92 Civic CX - Turbo H22A, 700+whp @ 29psi
10.42@144mph (148mph)
Good folks: Joe Simpson@Tempest Racing, Jeremy Allen@InlinePro
Mikey3000 is offline   Reply With Quote
Old 03-05-2012, 08:38 AM   #15
GoLowDrew
GoLowDrew's Avatar
New Question.
Impact Driver or Impact Wrench.
The way I see it is. One is female and one is male. Why the difference? I understand with extensions and adopters, they would be the same.
Which is better for this newbie?
Old 03-05-2012, 08:42 AM   #16
sCeRaXn
Honda-Tech Double Platinum Member
2000 Audi S4
My Garage
sCeRaXn's Avatar
sceraxn
Impact drivers were mostly designed/used for fasteners like self tapping screws. An impact wrench is actually made for nuts and bolts and will do that job better than an impact driver. Both are great tools to have though
Can you not hear the sounds of his love? They sounds like the skulls of babies being dashed upon the rocks...lovingly that is.
sCeRaXn is online now   Reply With Quote
Old 03-05-2012, 08:53 AM   #17
GoLowDrew
GoLowDrew's Avatar
Why is that? Educate me, since I can only have one.
Old 03-05-2012, 08:57 AM   #18
rice_classic
rice_classic's Avatar
Send a message via AIM to rice_classic
From another thread:
yes from the tool. An impact wrench provides only rotational force/impacts whereas an impact driver provides downward force/impacts in addition to rotational force...the latter somewhat similar to a hammer drill. Wikipedia has a somewhat useful definition of the two. AFAIK impact drivers are not commonly used in automotive work...that's usually the domain of impact wrenches. Impact drivers are great for screws and such. But in most automotive work....you don't really need the driving component of an impact driver. In fact...again AFAIK...it would be undesirable in the situation where you are trying to remove a fairly tight bolt....because the impact driver ...even in reverse mode...will be applying the downward impact as well...whereas the impact wrench will only apply rotational force...a good thing for a bolt you are trying to remove. However an impact driver might be the better tool to remove a frozen screw as it would tend to keep the head seated and minimize likelihood of stripping the head.Whilst impact wrenches, impact drivers, and hammer drills...all have some degree of overlap in function.
2011-2013 ICSCC ITA Champion
http://racecraftinstruction.com/
http://icscc.com/
rice_classic is online now   Reply With Quote
Old 03-05-2012, 08:57 AM   #19
1991civiclx13
Do you own a compressor? why can you only have one?
1991civiclx13 is online now   Reply With Quote
Old 03-05-2012, 08:59 AM   #20
ravinaziankid
ravinaziankid's Avatar
Send a message via AIM to ravinaziankid
I just did coilovers on my brother's car and even though we used an impact wrench, we still needed a breaker bar to break the strut bolts loose. All you would really need is a good set of tools and a nice breaker bar to do the job.
ravinaziankid is offline   Reply With Quote
Old 03-05-2012, 09:05 AM   #21
GoLowDrew
GoLowDrew's Avatar
Correct. I was just thinking of adding a tool to help out. My time and energy will be limited, so I want to make some steps easier to better spend it on other part of the install process.
Old 03-05-2012, 09:34 AM   #22
bad-monkey
bad-monkey's Avatar
Send a message via AIM to bad-monkey
my electric impact gun is one of my favorite tools in the garage.
bad-monkey is offline   Reply With Quote
Old 03-05-2012, 09:39 AM   #23
shamoo
2008 BMW M3
shamoo's Avatar
Well, unless I've had the definitions wrong all these years, impact drivers and impact wrenches/guns do entirely different things.
Impact drivers are usually hand held and are mostly used for loosening screws that just "fasten" things on and don't really tighten to anything. Think about those two stupid Philips screws that hold your brake rotor on. Do you think those two little screws actually hold your rotor on? They don't, really. They do hold the rotor on on the assembly line, but that's it. But to get them off, you need an impact driver. A regular screw driver won't budge them (but you can screw them back on with a regular screw driver).
This is a pic of an impact driver.
You "impact" the end of it to unscrew things like that pesky rotor screw. So far, through all my work on cars, it's the only thing I've had to use it for. I haven't seen an American car with screws on the rotors.
And impact wrench/gun is much more useful. I would get that if you were going to buy anything. You can get an electric one (I haven't used one, but I have heard good things). Or an air powered one (you need a compressor). They look like this.
Electric ones look the same, but are obviously plugged in.
I would get an impact wrench/gun if you were going to buy something to work on cars. It has made a lot of jobs easier. Keep in mind that it's the "impact" feature of the tool that makes it useful. It's good for getting off stubborn bolts like corroded suspension bolts.
Old 03-05-2012, 09:54 AM   #24
ravinaziankid
The one we were using is made by milwaukee and was around 300ish if i remember, it comes with an extra battery too.
I think this is the one.
http://www.northerntool.com/shop/too...5215_200385215
Old 03-05-2012, 12:32 PM   #25
Danza
2007 Acura TL
My Garage
Danza's Avatar
Send a message via AIM to Danza
Shamoo,
They make electric/pneumatic impact drivers that look similar to an impact wrench for those who aren't "in the know." That's why he asked.
OP, if you're just a casual mechanic. Pick up the craftsman 19V kits with an impact driver and impact wrench. Should be able to get a set with a couple batteries for <200 on sale.
The set screws on the rotor hold it on when the wheel is removed so you don't need to re-align the rotor everytime the wheel is off.
Comments or Statements made using this screen name are frequently made in jest. These statements do not represent the position of any organization or entity and should not be taken as factual commentary on any topic, to include the author.
Danza is offline   Reply With Quote
18, 38, adapter, bar, breaker, compared, cordless, drill, drills, electric, forum, gun, impact, socket, torque, volt, vs, work, wrench
